Need Xenon bulb help-newbie
I know I know I already searched and found a bunch of info but not what
Ia m looking for. I just bought a 95'sc400 with the Xenon light kit installed. Anyway the pass side headlight is out and I need to replace it. I pulled the airbox and thought the light would pop out the back but that is not the case, so I tried to take the entire assembly out but that wont work either. So how do I change the bulb? The lights say toyota on them so I think they are the newer lexus ones? The aftermarket wiring harness thing behind the bulb says toyota so I think the previous owner used toyota stuff and not a kit?
If I had the time to search I would but I need to get this taken care of today.
THANKS
BTW is the bulb a xenon 9006?
THANKS
VGRC51, no **** sherlock j/k. I meant that they are toyota parts and not some aftermarket company.
As far as the bulbs pulling strait out the back they have a rubber boot on them that is siliconed shut. I guess I will have to cut the boot to get at the bulb.
thanks
thanks
Originally Posted by VJ RC51
sounds like someone rigged something.. mine just twist out
I think you've got a retro on your hands. You have to take the headlight out and work on it that way to get the silicone off and bulb out.
Search in the SC forums on how to get your headlight out.
ThermonMer
Nov 12, 2011 01:29 PM
1BadAzzLex
Jan 16, 2003 09:11 PM
