Spark plug blow out
Old Feb 1, 2013 | 10:29 PM
A32Boost's Avatar
A32Boost
Default Spark plug blow out
Ok quick question for you fellow na-t guys what spark plugs are you running, what gap are u using, and what degree do you have the distributer set to?
Old Feb 3, 2013 | 08:33 PM
A32Boost's Avatar
A32Boost
hello no one?
Old Feb 4, 2013 | 03:35 AM
lexforlife's Avatar
lexforlife
need much more info on your setup as that info does affect my answer to your question
i run a ngk iridium plug in the 8 heat range which is a cold plug at my power level on pump gas it wards off chances of detonation ..cant answer you question about timing as im on a standalone so i set idle timing my way to whatever my car is happy at for a smooth idle as im heavily cammed and use a 90mm throttle body
Old Feb 4, 2013 | 09:58 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
lexforlife is right we need alot more info on your setup.
if you are on the stock ge ecu, then you will have to gap down alot. I always left the timing base 10 degrees.
at 11 psi back when I was on the stock ecu, I would have blowout unless I went down to .026 on BKR7EIX.
Not very impressive to say the least to have to gap down so far for 11 psi, but you are running 1 coil on a 6 cylinder turbo motor now so yeah thats why, and those plugs worked better than the coppers in that situation.
I would recommend looking into my TT ecu mod on the main SC forum, which will let you run coilpacks, then you can get back up to .032 or higher depending on your boost levels.
https://www.clublexus.com/forums/sc-...t-ecu-mod.html
vintagelex
Feb 5, 2013 01:15 PM
pcpitstop
GS - 1st Gen (1993-1997)
Aug 5, 2010 06:00 PM
AllblackLS
May 16, 2009 12:33 AM
papachulo
Performance
Jan 19, 2007 11:07 AM
HI98GS
Apr 25, 2001 01:06 PM
