Question about window trim?
Old Jan 17, 2013 | 07:06 AM
npiep's Avatar
npiep
Default Question about window trim?
My question is how did some of you all out there paint the chrome trim around the windows? I've tried searching and can't find anything about it so I figured I'd ask. I want to paint it black cause there is absolutely nothing else chrome on my car. So any help would be great. The pieces I am talking about are pictured below. Thanks
Old Jan 17, 2013 | 07:19 AM
chapabig's Avatar
chapabig
use Plasti-dip, it works like a charm
Old Jan 17, 2013 | 07:23 AM
npiep's Avatar
npiep
I tried to do that and it wasn't sticking to the black part then it would just peel right off the chrome maybe I taped it off wrong?
Old Jan 17, 2013 | 07:24 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
You remove the trim, and use plastidip, like Chapabig said.
EDIT The plasti-dip should work on chrome...
Old Jan 17, 2013 | 07:29 AM
npiep's Avatar
npiep
Ok so how exactly do you remove the trim I've tried to search this and I can't find it
Old Jan 17, 2013 | 07:43 AM
chapabig's Avatar
chapabig
You dont really have to remove the trim, the trick is to clean it real good, spray it with plasti dip (3 coats) do not take too long in between coats and remove tape right away, if you let the plasti dip dry before taking tape away, it will peel right off from your trim, remeber, that plasti-dip is like rubber, so if it dries, it will be stuck all together
Old Jan 17, 2013 | 07:50 AM
Teal Sc400's Avatar
Teal Sc400
I would simply remove the chrome on the trim, it's probably black and no need to paint.
Old Jan 17, 2013 | 08:04 AM
Joey-E's Avatar
Joey-E
I wouldnt do the Plasti-dip method, I tried it and it would peel off, I used "Blackout tape" and it holds up fine.
It looks alot better once you blackout that trim!
Old Jan 17, 2013 | 08:34 AM
sr71b's Avatar
sr71b
I had no problems with doing the plastidip on my car just used painters tape around the edges of the trim and just sprayed the car. The key is to do multiple thin coats, then to try and do thick ones. But i haven't had any issues with it peeling and its been on my car since september, so it has seen, heat, snow, rain, auto car washes, etc.
Old Jan 17, 2013 | 09:27 AM
TheAzn's Avatar
TheAzn
... I install vinyl films, I plan on wrapping my chrome trim in gloss black. Already did it to the B-Pillars that are part of the door that was some stupid gunmetal color.
Old Jan 17, 2013 | 12:12 PM
Tabaka's Avatar
Tabaka
Vinyl is another method. Just get yourself some matte black striping vinyl from 3M/ Avery / Oracal and a sharp razor / exacto for trimming.
Old Jan 17, 2013 | 02:20 PM
OG Dada's Avatar
OG Dada
It's not chrome btw, its stainless steel.
Old Jan 17, 2013 | 04:45 PM
Teal Sc400's Avatar
Teal Sc400
I believe the OP is talking about the small strip of chrome trim around the passenger/rear window of the Sc.
Old Jan 17, 2013 | 04:51 PM
OG Dada's Avatar
OG Dada
Yessir. That is stainless steel not chrome. I've painted mine.
Old Jan 17, 2013 | 05:21 PM
npiep's Avatar
npiep
KingPhilip how did you paint yours? Did you mask off the whole car and paint it or take it off then spray it?
