sc300 help
Old Jan 20, 2013 | 12:03 PM
TEAMxREX's Avatar
TEAMxREX
Default sc300 help
So i bought this sc300 last week for 3k with 270k on speedo but he got a different cluster so he says it really has around 180 but thats not my problem. When ever i drive the car for a long period of time or rev it high theres this bad burning smell...could be oil because i found a leak on my garage floor and ill raise the car to find it but i need help and ohh theres a rattle noise after i go in reverse duper stumped on that but please help.
Old Jan 20, 2013 | 12:57 PM
2jznosht's Avatar
2jznosht
What does the bad burning smell actually smell like
Old Jan 20, 2013 | 01:13 PM
TEAMxREX's Avatar
TEAMxREX
Like burning oil and i just changed the oil and oil filter and its not coming from the head either :/ its bugging me
Old Jan 20, 2013 | 01:14 PM
Kalogerus's Avatar
Kalogerus
What "leak" did you find on your garage floor? Motor oil? Transmission oil? Power steering fluid? ...etc. That should help determine the issue a little bit more.
Oil pan leaks but wont give a burning smell. Valve cover gaskets leak as well.
Old Jan 20, 2013 | 01:19 PM
TEAMxREX's Avatar
TEAMxREX
It was golden so motor oil i suppose and what could the smell be? Oil pump? Gas filter? Its only high revs
Old Jan 20, 2013 | 03:21 PM
2jznosht's Avatar
2jznosht
Start by tracking down the leak. The burning is likely from the leak hitting something hot and burning. While its sitting whatever is leaking probably just drips till it hits the ground. Also what to you is high revs
Old Jan 20, 2013 | 05:10 PM
TEAMxREX's Avatar
TEAMxREX
Hmm..ok and around 5k
Old Jan 20, 2013 | 07:16 PM
TEAMxREX's Avatar
TEAMxREX
By the way my car is lowered a lot lol this is my semi daily car and drift car
Old Jan 20, 2013 | 10:42 PM
2jznosht's Avatar
2jznosht
Standard or auto?
Old Jan 21, 2013 | 07:51 AM
TEAMxREX's Avatar
TEAMxREX
Standard
Old Jan 22, 2013 | 07:26 AM
TEAMxREX's Avatar
TEAMxREX
Ok the leaking oil went away for some reason but the smell is still there
ALLWiTE2JZ
Jun 17, 2017 12:06 PM
durtysc300
Apr 27, 2010 04:38 PM
shoehead
Maintenance
Aug 28, 2005 09:49 PM
TouringGS
Performance
Feb 8, 2004 12:46 PM
Francis K
Nov 5, 2001 02:29 PM
