HELP! ECU problem?
Old Jan 23, 2013 | 09:16 AM
dandd2's Avatar
dandd2
Default HELP! ECU problem?
I purchased this vehicle:
https://www.clublexus.com/forums/lex...c400-auto.html
while i was driving it the other day the car cut off after about 40min of highway driving.
i had to jump the car so i thought it was a battery issue. i tried to jump and start and car would not crank over.
from my mechanic he is saying that there is no signal to the injectors. he thinks it is a crank shaft sensor or ecu issue?
please anyone else have this issue before? has a soarer ecu?
thanks in advance
Old Jan 24, 2013 | 07:16 AM
Jostar's Avatar
Jostar
The motor cranks but does not fire right? if yes, I would check the ECU 1st, anyone local to you that has a 1jz swap that can help you test with their ECU?
CelsiorN1
Aug 27, 2023 05:49 PM
GS FONZy
Feb 4, 2017 04:40 PM
MrSlopra
Oct 17, 2012 08:57 PM
kikcaffine
Southeast
Mar 15, 2011 12:06 PM
