Keep hydro fan or replace with clutch fan from LS400
Old Jan 17, 2016 | 05:28 PM
M.Rad.'s Avatar
M.Rad.
Default Keep hydro fan or replace with clutch fan from LS400
Hello again campers! As you saw in my previous post regarding my catastrophic valve bender incident, I will be swapping out my damaged engine for one from a wrecking yard. It is out of a 96 LS400. If I remember correctly, the LS has a clutch fan as opposed to the SC's hydro fan.
I am considering dumping the hydro fan in favor of the simpler clutch fan setup.
Any thoughts?
Regards,
M.Rad.
UPDATE: Well, it looks like there is no easy way to swap over the LS based clutch fan into the SC. The stock fan shroud is off-set to the wrong side, the LS fan shroud doesn't fit, the LS fan onterferes with the radiator hose, etc.
I bought an electric fan from the junk yard ($20) and a wiring kit / thermostat from O'Riley ($25). Mounted in stock fan shroud-works well.
ninja757
Nov 12, 2017 04:21 PM
CrispyST3
Sep 23, 2016 12:41 AM
98Sc3001jz
SC400 / 300 Classifieds
Jul 23, 2014 09:09 AM
SC3Monster
Jun 7, 2013 05:23 AM
Legionofon
Mar 12, 2010 04:48 PM
