Spark Plug Troubles
Old Jan 16, 2016 | 09:01 PM
TheAzn's Avatar
TheAzn
Default Spark Plug Troubles
This is the work of the previous owner, or shop. Somehow they had installed a wrong spark plug for what reason I don't know.
5 spark plugs were NGK's while one was Denso which I had problems with, on Cyl 2. Unfortunately the plug hole is stripped bad.
Going to helicoil it and go from there. If it fails, next option is to replace the head.
Love your SC's. Don't do this kind of crap.
Somehow, for 70k+ miles I have driven this not knowing it was like this, there were no running issues. Only has been recent that I've been getting a minor misfire under heavy acceleration.
1995 SC300 5-Speed, everything underhood is original with 324k miles.
Old Jan 16, 2016 | 09:32 PM
Bdub215's Avatar
Bdub215
A Denso SK20R11 (which is what that looks like) is a drop in plug for this motor. It's a iridium long life plug good for 100K. Now how it got to that condition I have a solid guess but neither you nor I can prove it. I say someone installed it with a impact gun or driver of some kind.
If I can help in any way even though I'm 2 hours away, let me know.
Old Jan 16, 2016 | 10:05 PM
salimshah's Avatar
salimshah
25 Year Member
May I suggest a pass with heavily doped tap (same pitch and dia of the plug) with repeat pull outs and fresh grease.
Why: At least 1/2 the threads look good (unless while extracting the damaged tip end destroyed the good threads of the head. And if the new plug gets torqued in and you dont see any leak then it would be a cheap fix.
If things fail then helicoil or re-worked head.
Salim
Old Jan 16, 2016 | 11:44 PM
mikef's Avatar
mikef
I would slowly put a new plug in to see how much threading you can get then take it out to check it. all else fails just get a head
Old Jan 19, 2016 | 10:30 AM
Sc375's Avatar
Sc375
At 3xx,xxx miles the valve guides are probably shot, you should have the head taken off and refreshed by a shop and fixed at the same time, get the guides replaced and a valve job. shes put in her work for 300k time for a major tune up if you plan on keeping the car long term
Old Jan 19, 2016 | 10:49 AM
freakness's Avatar
freakness
Dudes,
Regardless of the stripped thread, the cylinder head is in need of a rebuild, given the high mileage; I am assuming it hasn't been rebuilt in the past 100,000 miles. If you remove the head from the car it can be repaired with a Timesert rather than a helicoil. A Time-sert repair is more durable, it is a permanent repair; helicoil repairs sometimes strip/pull out although they are easier to install. I used a Time-sert repair kit to replace a stripped headbolt thread on my Toyota truck's 22R long block; it's been running great for the past 5,000 miles.
- good luck
Old Jan 19, 2016 | 01:09 PM
CatManD3W's Avatar
CatManD3W
Those plugs are bad....rule of thumb is to change them frequently......
I buy them in bulk and change them at every oil change......but that for me is about 2 times a year since mine is not my DD..
Old Jan 22, 2016 | 11:27 PM
jstrummer's Avatar
jstrummer
Can you explain the logic of changing them so frequently?
is3504bao
Sep 23, 2022 11:01 AM
nezlyfe
Nov 21, 2017 10:19 AM
sc_lang
Jun 24, 2007 09:01 PM
GOLDSc300
Aug 9, 2002 09:53 PM
