Intake for a 00' Gs4
I want to get a intake...preferrably a Cold air intake...Any ideaS?
I've heard that these are the good ones, im not sure if they are cold air or not :
Injen
K&n
Aem
Iceman
Please let me know if which intake would be the best without installing a Ecu chip. the chip is out of my budget for know since im buying new rims and a bodykit.
I think all the other kits out there that don't have a tube directing to cold air hurts the performance cause it is sucking in HOT engine compartment air...To me, it doesn't even look cool. It takes away from the elegance of the engine compartment too. Sometimes, stock is best...How else can you crank out 300HP out of a 4.0L. THE VVT-i is AWESOME!
Personally, I think most of the kits out there are degrading the stock box and cold air intake it already has. It's simple, the stock box has a tube that directs to the front of the car that can take in cold air, right in front of the radiator. That is the best thing you can do. Some people on the forum have made their own custom cold air intakes that probably can do a little better. I say just get a drop in filter to the stock box (K&N) and like I did, I guided the cold air from the front of the grille more towards the tube from the stock box. Let me know if your interested, and I can give you more details. The way its setup, it's almost like ram air...at a low cost budget...
If you look at most of the aftermarket systems, their owners still try to re-modify it to take in cold air. Or the create a custom enclosure, (like stock, but obviously bigger) and does the same thing, but if you aren't directing the cold air in there, even though you are sucking in more, it is more hot air not cold, like the stock that is directed to the outside of the engine compartment.
Under normal driving conditions, or even racing conditions, it is best that you direct cold air into your intake.
There are aftermarket intakes that are better than stock. But if they don't direct cold air to the throttle body, it was made for looks and show, rather than performance. Also, metallic tubing absorbs more heat than plastic, though it doesn't look as nice and shiny, plastic tubing is the way to go, for performance. And if you get one that has a heat shield, make sure the heat shield is made from fiber glass, and stay away from metallic substances, it absorbs more heat...
Enjoy....
Cold air intake + SRT would be ideal I'm sure but SRT by itself seems to be pretty good as well. Might be something for SRT to work on for their next design!
Regards,
Doesn't the SRT system change the ECU as well?....Has anyone tried changing the ECU without changing the intake system hardware as a test?
Also, do a Search. The Intakes for the GS have been discussed about a <insert Dr. Evil tone here> 1 billion times.
