HELP, Im having tranny issues..I think!!!
Im having a hard time believing that a Lexus with 38k miles on it, driven pretty damn modestly, is having tranny issues already(out of warranty of course). I do have the RMM limited slip and TQ, could this be the issue, im just grasping at this point. Its been so long since I had a car with an auto tranny, Im not even sure of the dynamics of it. Would an auto tranny have parts that would be burning. like a clutch plate, etc...?
I am pissed off at the moment!
Make sure you check the transmission fluid level. If it is low, you won't develop enough pressure and your torque convertor will not engage. Make sure you add the Toyota type IV fluid. Don't add any other type of tranny fluid.
hope this helps
ricky
Sorry to hear about your tranny problem. About 2 years ago I killed my tranny with just over 50k miles. Somehow the fluid got low (tranny shop blamed the pump) and my T/C (PI purchased from RMM) got killed - metal all thru the tranny. Lexus denied the warranty claim due to the after market T/C. I ended up having Level 10 rebuild it for just north of $3k.
If you definitely think you're having tranny problems, put back your stock converter before you take it to the dealer. If you bought the car new, your tranny warranty is good for 70k miles.
Good luck
Kenny
I am assuming you have all religiously followed your factory recommended maintenance schedule (I am pretty sure all of us that modify our cars so much, pay more importance to the maintenance schedule than your typical owner). So I don't understand why this should ever become an issue.
I mean between service intervals when fluid levels are checked, surely this would have been discovered way before it ever became a problem........................ ?
What am I missing here? Enlighten me bro's..................
Its just one of those things I didnt expect to have issues with I geuss.Mariusz, Im not sure what the stall is, I bought the car with it on already. If Im not mistaken, RMM carries different TC with different stall #'s. I do not have a tranny cooler though, maybe I should look into getting one.
My PCTC Install Page
Off the top of my head, PearlPower, tomtnc, DaveGS4, banannaGS, and myself have all added aux coolers.
Good Luck
I added PearlPower's great kit with custom pre-bent pipes / fittings.
Here is his sweet install:
PP's Polished Tranny Cooler Install Thread
Edit: Also tinygs's Install Thread
