Projector lights issue/ IS350 2012
Old May 17, 2018 | 03:54 AM
hamoochie's Avatar
hamoochie
Default Projector lights issue/ IS350 2012
Hii guys, i have an is350 2012. I bought the car recently with ISF headlights on them. The problem is that the Bottom white led strip wont light up at all however the orange indicator strip works perfectly fine. Anyone here who knows what might be the issue?
Old May 20, 2018 | 08:52 AM
whitebeast's Avatar
whitebeast
The headlight you got is aftermarket light, not from ISF.
fir the DRL led, you would have to turn the light switch one Click (parking light)
Old May 22, 2018 | 01:22 PM
hamoochie's Avatar
hamoochie
i did not quite get you brother. Do you mind elaborating a little?
Old May 22, 2018 | 01:44 PM
Zmon's Avatar
Zmon
The headlights you have are not the original headlights that came on the car. No 2011+ IS250/350 has an orange LED strip. Which, honestly is a bit odd since the IS350 of those years came standard with the HID/LED strip headlights so I have no clue why the original owner would of swapped the headlights for cheap aftermarket junk just to have an orange strip.
Old May 23, 2018 | 11:43 PM
whitebeast's Avatar
whitebeast
Like Zmon Stated,
OEM led headlight won't have orange turn signal light. On top of that, The shape and quality of those aftermarket light nothing match OEM. Most of us (whose do conversion LED headlight) will re-pin or re-wire to make the LED light strip turn on whenever the ING is on.
I bet your headlight is just plug and play (without re-wire) so you would need to turn the light switch to parking light - one click before for turning on the low bean - to turn on the white LED strip
Old May 28, 2018 | 03:11 AM
hamoochie's Avatar
hamoochie
Like Zmon Stated,
Oh i c, but i am pretty sure it is not as simple as parking switch to turn them on. I have tried all the switches. Anyway i will head to the mechanic to check them out.
Thankyou guys for your input.
Old May 28, 2018 | 01:47 PM
ProxyLexi's Avatar
ProxyLexi
The Spec-D LED headlights you have are prone to failure mostly like the LED's burned out. The orange light you are seeing is a separate bulb that is just reflecting on the LED strip. Your only option is to order a new replacement or bake the headlight and fix the LED's.
williakz
Oct 10, 2022 11:49 AM
smt6
Sep 19, 2016 09:28 PM
Navydoc13
IS F (2008-2014)
Aug 5, 2015 04:24 PM
MGB1120
Dec 3, 2014 06:30 AM
ISFast08
IS F (2008-2014)
13
Jun 15, 2012 05:47 PM
