Help!!! Airbag light!
Old 05-11-18, 07:13 AM
Demon9059
Demon9059's Avatar
Default Help!!! Airbag light!
I have a 09 IS250. It was in a light accident no airbags deployed. I have it all put back together and there is a airbag light code b1650 for occupant classification sensor and when I run zero point calibration code b1797 comes up with abnormal calibration. When I do live data stream on the computer and push down on the seat it still shows weight like someone is sitting in it. I am stuck on what I should do to get the light to go out thanks.
Old 12-31-18, 12:18 PM
RonyP1982
RonyP1982's Avatar
did you ever get this issue resolved???
Old 02-03-20, 02:15 PM
KPH65
KPH65's Avatar
Read this article. My code popped up when it was scanned
https://diag.net/msg/m1cgjxxvnwfho964ndt02zkkd8
Old 02-04-20, 10:45 AM
RonyP1982
RonyP1982's Avatar
I been to that thread but never actually got a solution. Are you having the same issues if so were you able to resolve them??
Old 02-06-20, 05:42 AM
KPH65
KPH65's Avatar
Try the OCC zero calibration first. If that does not work go to youtube and pull up the 3 videos from Joe Portelinha dealing with the issue.
More often than not when you can't zero calibrate its because the airbag computer has corrupted software.
Old 02-06-20, 06:57 AM
RonyP1982
RonyP1982's Avatar
I'm trying to make sense of his process though. Did he use another computer copied the data from that then copied it back to the corrupted one??
Old 02-06-20, 08:01 AM
KPH65
KPH65's Avatar
Thats how i understood it. Looks like he uses tech stream to upload the data/software from a new/used airbag computer than downloads that
info the corrupted one.
Old 02-06-20, 08:06 AM
RonyP1982
RonyP1982's Avatar
guess I'm going to give that a try hopefully it works out thanks for the info I appreciate it
Old 02-06-20, 08:16 AM
RonyP1982
RonyP1982's Avatar
how did you resolve your problem???
Old 02-06-20, 09:06 AM
KPH65
KPH65's Avatar
I purchased the car used with a warranty. Im taking it back to the dealership for the third time next wednesday which is way I've done some research on this.
My fix will likely be very much like the Joe Portelinha fix.
Old 02-06-20, 09:08 AM
RonyP1982
RonyP1982's Avatar
o okay lmk how that goes my cousin has a 2011 is250 gotta see if I can copy his computer
Old 02-06-20, 09:09 AM
KPH65
KPH65's Avatar
Good luck with the fix. Post when you get it done.
RonyP1982 (02-06-20)
Old 02-06-20, 09:27 AM
KPH65
KPH65's Avatar
if you don't want to reset the airbag ecu yourself this may be a possible solution.
https://blogs.myairbags.com/how-it-w...-module-reset/
Old 02-06-20, 09:32 AM
RonyP1982
RonyP1982's Avatar
I called that place before and the girl who answered the phone was kind of clueless to what I was talking to her about but maybe I'll call again see what they tell me
Old 04-20-20, 01:42 PM
tastfulmod
tastfulmod's Avatar
I just completed this. Followed Joe Portelinha's videos and it worked. You will need a non corrupted module to copy the software from but make sure you use the same exact part number. This corruption is caused by snap-on scan tools.
ejdossary
RX - 1st Gen (1999-2003)
04-20-20 07:50 PM
PhilTyler
06-21-17 09:04 AM
Grimpy
SC- 1st Gen (1992-2000)
02-11-03 10:30 AM
TypeSC300
08-21-01 05:14 PM
Quick Reply: Help!!! Airbag light!
