Product Inquiry: Replacing Front LCAs
So I am giong to finally replace both front LCAs on my 2012 is250 RWD. Sorry for the stupid question but I just want to make sure....Do the two products below come with the bushings as well? Is there anything else I am going to need to order to go along with this part when replacing the front LCAs???
Thanks!
https://www.rockauto.com/en/moreinfo...502576&jsn=517
https://www.rockauto.com/en/moreinfo...502576&jsn=515
Thanks!
I did ask them and I got a trash response. Like literally the most useless response ever lol
"All of the information we have on the products we sell is listed on our website.
If you're not seeing the details you are looking for, then we do not have them. That also means they are not important. The manufacturer always lists the details that will be important to determine if the part will fit your vehicle.
Thank you,
Jim D.
RockAuto Customer Service
^^^^Uh, OK. Understand. Accident damage. I have replaced the LCA bushings in my ISF with RRRacing's stiffer USRS bushings. I also sold my bushings to an ISX50 owner because they were a little stiffer than the stock ISX50 ones. But, if you have confirmed damage to the LCA assemblies, then, of course replacement is the correct action.
Lou
Lou
Are you sure they don't come with bushings? ?
https://www.carid.com/moog/r-series-front-driver-side-lower-non-adjustable-control-arm-mpn-rk642162.html the description says they do...
Keeping it Real
https://www.carid.com/moog/r-series-...-rk642162.html the description says they do...
Jeff
Ahhh gotcha well the mechanic told me there was play in my front LCA bushings so im guessing that bushing that has the issue is the bushing that is included in the products im looking at. Correct?
Thanks.
Thanks.
Keeping it Real
Oh, for sure, if it's the forward bushing on the front lower control arm that you're having issues with, these will include that bushing.
(The forward and rearward bushings are both "front lower control arm bushings," so I didn't realize you meant the front one on the front arm. )
Jeff
Jeff
Jeff
Jeff
Do you know if I'll need to replace the ball joints up front too? Someone on reddit told me that if I'm replacing the front LCAs and bushings that I have to replace the ball joints too
I wonder if I should just replace the rear bushings too...
