2006 IS350 Throttle Body Cleaning Part 2
Cleaned the Throttle Body this morning. It wasn't as bad as I thought it would be, actually kind of clean after 94k miles. I sprayed some TB Cleaner on the screen to the Intake and gave a few shots of Sea Foam into the Intake also. Sprayed it down and let it sit for a little and then used soem more TB Cleaner and a tooth brush and just gently scrubbed. Here are some photo's and this was the previous thread from a couple of days ago.
https://www.clublexus.com/forums/is-...-cleaning.html
2006 IS 350
TB Condition
Black Ring around Flap
TB Condition
TB Inside Condition
Screen
Cleaned
2006 IS 350
TB Condition
TB Condition
TB Inside Condition
Screen
Cleaned
For those reading this, BE CAREFUL when turning the butterfly plate within the TB. The plate is attached to an electric motor; and unlike older vehicles with a physical cable connecting the throttle to the gas pedal, the motor is electrical and issues can arise if moving the plate around at will.
