PDA
View Full Version : LS - 3rd Gen (2001-2006)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
  1. Squated with spring clamps
  2. HVAC Vents Blowing air when closed? DIY Video
  3. Locked out… no way in
  4. Rear shock replacement
  5. Cluster issues
  6. Pirelli P7 AS Plus 3 Discontinued in 17” - alternative sizes
  7. Can I disconnect and remove the cd changer with no function loss
  8. 2002 Lexus 430 VSC and Check Engine Light and Stall
  9. Motor Mounts and Lower Oil Pan #2 - DIY Video
  10. PO430 exhaust gasket question.
  11. LS430 backfiring
  12. LS swap ls430
  13. 2006 LS430 Road Noise
  14. What is this hose exactly?
  15. Gas Tank
  16. Charcoal Canister EVAP Replacement Video Emissions Check Engine Light
  17. To those that have run any type of wiring from the cabin into the trunk.....
  18. Parts help
  19. Extended studs and spacers
  20. Do sun visor vanity lights stay on once the car is off?
  21. Could a ride height sensor be bad and not throw a code?
  22. 2004 LS430 ML… Electrical issues after rain
  23. Valve Cover Gasket and "while I'm in there"
  24. 2002 430 Clock internal temp display not working
  25. Sc400 wheels
  26. Auto sensing wipers stopped working.
  27. LS430 Line Output Converter Help
  28. Screen replacement
  29. Wald Duchatelet 2 Nut
  30. Blocked Sunroof Drains
  31. Any Mechanics in LA/SoCal?
  32. Jonesing for an LS 430
  33. Keep or sell 05 LS430 with some issues?
  34. Belt change shy of 194k miles
  35. Ls430 brake change advice!
  36. Obsession with 04-06
  37. Non Sport Spring on Sport Shock?
  38. tire pressure reset switch
  39. Changing Spark plugs
  40. Lexus Ls430 Engine to Lean P0171 P0174 + Gearbox Problems
  41. Clatter noise at startup!
  42. 2006 LS 430 18” wheels
  43. Replace nav system 2004 LS430
  44. Does anyone know the story behind the dealer option chrome 5 spoke wheels?
  45. Narrow tires
  46. Misfire on idle
  47. How many times a day should your UL air suspension's compressor turn on?
  48. 2002 Lexus ls430 crazy electrical issues after rain
  49. im stuck need HELP charcoal canister R&R
  50. R&R charcoal canister need help to get the axle out of the way got
  51. MOPAR Coolant
  52. P01354 wont clear please help
  53. Can you Hook up an aftermarket amp and sub to factory ML radio.
  54. Lexus LS430 CL front passenger window broken - options?
  55. LS 430 search
  56. Issue with Rod for Battery Bracket
  57. Engine ECU Communication Stop * DTC B1261
  58. Potential new 430 owner…
  59. Where to buy OEM Weather mats.
  60. Morning sickness-additive recommendation
  61. Ecu not recognized
  62. Can you fry multiple fuses or alt fuse from sound system
  63. how to ID genuine brake rotors?
  64. Windshield wiper arms not going down all the way
  65. Does this look like a spark plug seal leak? See pics.
  66. Has anyone bought/installed reman. calipers recently?
  67. 2001 front drivers seat cushion replacement.
  68. 2004 for $5900, 175k, bought it! Am I crazy?
  69. Rodent corpse removal
  70. Issues after replacing passenger fuse box
  71. Replacing the Starter Motor on a 2006 LS430...
  72. Bumper repair
  73. 2002 lexus ls430 vcs
  74. Valve train cleaniness
  75. Locked out of trunk / 2001 LS430
  76. 2004 LS 430 replace counterfeit oil filter
  77. Should you Use a Gas Additive for a Smoother Engine
  78. Drivers cup holders
  79. Anyone use AT205?
  80. Water trickling sound?
  81. Replace or Rebuild Transmission?
  82. Creaky driver door
  83. PFL '03 Headlight adjustment?
  84. Brake noise
  85. Driver's Seat bottom leather replacement - Guinea Pig
  86. A pillar trim
  87. Unique Style Racing Taillights?
  88. 2002 LS430 ML - Only Tweeters Work
  89. 2001-2003 Air Suspension Repair, Video, Part Numbers
  90. Coolant antifreeze loss leak finally solved. 2 bad radiators and non-OEM clamps.
  91. Anyone know how lexus heated steering wheels work?
  92. Everyone with aftermarket air ride - please post a pic of your trunk
  93. What would I get for my 2004 LS 430, 156k well maintained, owned since 60k miles
  94. VVT Solenoid O-Ring Size
  95. Misfiring
  96. Does it look like the radiator or the reservoir leaking? Pics inside
  97. Remote key not responding, but I can still use keyless start 02 model
  98. Hard Shifts - Very Low Speeds
  99. To Buy or Not to Buy (Monroe Quick Struts)?
  100. Leaking moonroof
  101. Carista
  102. 2003 gem - not mine
  103. Buying a LS430 with high milage? help
  104. Why is Engine starting To Idle Rough
  105. 2001 LS430 stock headlight bulb question
  106. Adjusting PFL headlights
  107. Front Hood Struts
  108. Authentic OEM AISIN timing belt kit
  109. Current owners - what are your views of these 2 issues found in PPI?
  110. Whining Noise, thoughts?
  111. Whats this noise? Help 🙏
  112. "03 LS 430 230000 worth?
  113. So long farewell adieu
  114. Full air suspension replaced and rear right side sagging
  115. Oygen sensor connector came off the wires
  116. 2001 Weird codes
  117. LS430 Budget Friendly Reliable Coilover Brands
  118. torque for transmission refill/drain plug for 2005 ls430
  119. Overdrive?
  120. 2005 Ls430 on coilovers (need some help)
  121. What OBD reader will not trigger vsc light?
  122. How did Lexus do it? I’m amazed.
  123. Will the older style 17 inch 7 spoke chrome wheels fit on a 04-06?
  124. Need advice: 2004 sticky door lock
  125. Control arm and ball joints
  126. High pitched low volume noises from the dash
  127. Fun new project
  128. Owners - how did you find your LS430?
  129. Cupholders
  130. SiriusXM “Antenna” “Antenna”
  131. How common are "common" problems?
  132. ASC controller for 2001 ls430
  133. Is my 2006 LS430 running too cold? Video here.
  134. 2005 LS430 Front Crankshaft Oil Leak
  135. Ongoing vsv or something else?
  136. Flashing check engine light, VSC light, shaking car
  137. 2004-2006 LS430: Can I upgrade trim level features?
  138. Proximity Smart Key Unlock Issue
  139. speakers
  140. RockAuto is slipping badly
  141. JDM windshield wipers
  142. Problem with heater in my '05 LS430
  143. 2001 – Engine Lights – Bad Computer Module?
  144. Some questions - 2005 LS430
  145. Pretty rare color combo if anyone is looking
  146. Do I need a new fuse box?
  147. Help troubleshooting a quiet ML sub
  148. Repaint or replace door?
  149. Blown Head Gasket - Need Guidance On Replacement
  150. Third catalytic converter (middle) replacement options?
  151. Steering wheel cover 04 LS
  152. Nav screen shutdown?
  153. Strange rumble from front wheels
  154. Fun with a cabin air filter swap.....
  155. Screen issue 02 Ls430
  156. 2004 LS430 auto fold mirrors
  157. transmission problem
  158. Quick question on the MAF/IAT sensor
  159. LS430 2001: Narrowing down a possible rear suspension noise
  160. What are you'r favorite things to use techstream to program your LS430?
  161. Just picked up some factory exhaust parts
  162. I got a Tranny issue P0761 code
  163. Battery Low - Car Turned Over But Did Not Run
  164. Mystery scraping noise during turns
  165. 2001 Ls 430
  166. I finally bought one! An 05 Custom Luxury LS 430.
  167. Transmission problems
  168. oil change and jiffy lube incompetence
  169. Fuel Gauge Showing Empty
  170. LS Gen 3 Facelift details
  171. Factory sub replacement problem
  172. Production by color and Trim level??
  173. No more updates, maint reqd stuck on dash
  174. 2004 LS 430 radio no sound
  175. Scotty, I need MORE POWER!
  176. LS430 Rear Headrest TVs
  177. P2112 (Throttle Actuator Control System Stuck Closed)
  178. Anyone using Lucas transmission on '03 Lexus LS430 ??
  179. Bearing noise at speed but spins OK
  180. CEL (P0171)/Check VSC/Traction Control Light
  181. LS430 2004, Smartkey doesn't work/switch doesn't rotate
  182. 2005 LS430 Smart Key Issue. Cannot register new key after seed code reset.
  183. LS 430 Lower Control Arm Bushings
  184. Why does my standard suspension LS have a "height control" sensor arm?
  185. Need help - dash and gauge cluster switching languages
  186. How to replace radar crusie module from from bumper
  187. Trying to find the source of / cause of this pesky cooland leak. 2006 LS430 125k mile
  188. What’s a good price for a UL LS 430?
  189. purchase advice ~ any concerns with a Denver, CO car?
  190. Part number for harness clips on timing belt cover
  191. How rare is a UL with Black Cherry on Bordeaux?
  192. Finding Techstream V12
  193. 2005 LS 430 won’t crank
  194. trunk release
  195. Need help! Lost key, dealer is $$$$. It sure about locksmiths programming
  196. Cali smog legal mufflers/exhaust mods
  197. Lost my only key, dealer wants $1200, use a locksmith ?
  198. SoCal/SGV shop
  199. Non-dealer mechanic (not struts, now what?)
  200. Clockspring replacement
  201. o2 sensor harness replacement
  202. Rear driver door won’t latch
  203. Arctic Exhaust Y-Pipe
  204. Aux adapter
  205. Please Help - Cylinder 2 misfire
  206. LS430 18s chrome wheel question
  207. 2006 ML. Door does not unlock when I touch handle. FOB must be in ignition to start.
  208. Crossover point for dash speakers
  209. timing belt life span?
  210. ticking coming from driver front rotor
  211. Need a chrome trim for the front bumper - No OEM replacement?
  212. Oil burning
  213. Full suspension refresh - do I need anything else?
  214. Adjusting headrests
  215. New Struts All Around - Advice?
  216. Any ideas on how to fix the driver side door
  217. 02 Ls430 trunk storage extension removal
  218. Will these fit on my friends LS430?
  219. Idling High
  220. FIGS Engineering UCA and LCA
  221. Bluetooth Audio and Navigation
  222. EGR Problem?
  223. Rust questions
  224. Interesting Key dilema
  225. Lower oil pan bolts part number?
  226. Electric seats
  227. Rumbling from front end - WWYD?
  228. Audio Options
  229. AFS system malfunction 2006 LS430
  230. Reverse gear seems to be sticking when the car is coming to a stop
  231. 2004 LS430 sport suspension struts
  232. LS430-2004: Bushing type No MArk, White Mark, Pink Mark
  233. Location of AC pressure circuit on 2001?
  234. “New” 2004, Trunk button inop
  235. Car surges/lunges a bit after hard breaking
  236. Bizzare audio/ electrical issues
  237. 55 Watt HID Ballast- Anyone use this?
  238. 2004 UL air shocks or OEM Lexus non-sport shocks??
  239. Transmission fluid level with dip stick
  240. Sporadic Trouble Starting
  241. Quick fitment question
  242. Power tilt help
  243. Rear Tail Light Question- Help
  244. 2003 no history of trans fluid being done, 163k
  245. Car Behaving as if Battery's Been Disconnected
  246. Any idea what these little parts are for?
  247. Mechanic Recommendation in NYC area
  248. How to replace lower oil pan gasket
  249. Should I get a new gas cap?
  250. Rusted Rear Differential Drain Bolt
