Whats this noise? Help 🙏
Old Dec 11, 2023 | 09:35 PM
RaeBarBie's Avatar
RaeBarBie
9th Gear
Default Whats this noise? Help 🙏
I jumpstarted my car this morning. Its been sitting a while, but as soon as it turned on this sound ive never heard started coming from the engine area i believe. Ive attached a video. Any help or suggestions would be greatly appreciated!!
File Type: avi
Old Dec 12, 2023 | 05:39 PM
tealchief's Avatar
tealchief
The timing belt has to be the issue, this sounds like ****ing tractor. Replace belt.
Old Dec 12, 2023 | 06:16 PM
LS430inDE.'s Avatar
LS430inDE.
Sounds like a lubrication issue to me.
What does your oil level look like? When was it changed last? Is it the correct viscosity?
Old Dec 13, 2023 | 07:48 AM
Yamae's Avatar
Yamae
+1 for the lubrication issue.
How long has it been sitting?
After sitting for many weeks, UZ engines tend to sound like that way but it becomes normal within a minute or less.
Old Dec 13, 2023 | 08:01 AM
weldthedif's Avatar
weldthedif
could be a lot of things. take the serpentine belt off and spin each component individually (alternator, ac , tensioner, etc.) see if the bearings in them seem bad. rule out the easiest things first.
Old Dec 14, 2023 | 07:30 AM
BigBoomer's Avatar
BigBoomer
Sounds to me like it is way louder on the left side of the vehicle, but it's idling fine so I doubt it is the timing belt.
Could be a crack in a header on that side, or maybe one of the bolts holding the CAT on has given up and the CAT is vibrating against the header?
It's metal on metal, so I really would not drive it far until you figure it out.
Old Dec 29, 2023 | 03:54 PM
RaeBarBie's Avatar
RaeBarBie
9th Gear
Default Thanks for responding!
My oil level is fine, but the car has been sitting very long time like over a year because I couldn't figure out what was wrong with a leak in my evap. I FINALLY did a smoke test recently and found out where it was coming from the ACIS Actuator? Would that have anything to do with this noise??
Old Jan 6, 2024 | 08:38 AM
RaeBarBie's Avatar
RaeBarBie
9th Gear
Edit Quote Multi
Old Feb 22, 2024 | 12:15 AM
13mm's Avatar
13mm
1st Gear
a disconnected hose at the purge valve makes that noise. would explain your evap problem
TrashMando
Oct 12, 2023 05:32 AM
Shinick
Jul 15, 2023 05:19 PM
RaLexoRas
Oct 13, 2021 11:01 AM
AntzCro
Mar 16, 2015 06:46 PM
98gslex
May 6, 2009 12:10 PM
