Ecu not recognized
Old Jan 19, 2024 | 02:37 PM
tyrocksalot's Avatar
tyrocksalot
6th Gear
Default Ecu not recognized
Obd2 scanner won't connect to ECU. I have no dash lights, headlights, brake lights, or horn among other things. All the fuses under the hood visually look fine. I hear a relay clicking maybe efi main? That's only when battery is unhooked for a short time and headlights and dash lights work for about 2 seconds. This happened after I shorted the factory amp connector :/
Also no crank or start
Old Jan 19, 2024 | 03:01 PM
alextv's Avatar
alextv
There are also fuse areas on driver and passenger sides inside. Passenger side above kick panel is the radio and probably amp fuse also. Sounds like more than just a fuse and it really depends on what you shorted out. Use a multimeter to diagnose.
Old Jan 19, 2024 | 03:28 PM
tyrocksalot
6th Gear
Visually all the fuses are fine. Now I'm getting ZERO power to anything
Old Jan 19, 2024 | 08:05 PM
xtr3me's Avatar
xtr3me
I have same issue, no communication with ECU, only cooling fan runs with key turned to on position, cranks but no start, no CEL in display,fuel pump relay clicks when key 1st turned on
On drivers side, fuse block near battery , look thru plastic tops of fuses to see if blown, pay particular attention to 140 amp Alternator & 80 amp P/J, this is the fusible link
Old Jan 19, 2024 | 10:35 PM
tyrocksalot
6th Gear
All fuses look good. Took 140a off and took cover off of it looks pristine. And so do the 80amps. Checked all the fuses of things not working. They are fine as well. Everything points to a fusible link, but they look fine
Mine won't crank or start and NOTHING works except a few dash lights cel etc
Old Jan 19, 2024 | 11:55 PM
Yamae's Avatar
Yamae
Without the ECU, the engine still can crank but no start.
What I worry about is that the ECU is not getting the power from the battery. Something must be stopping it. Judging from your words, "NOTHING works except a few dash lights cel etc", I suspect that the AM2 line of the ignition switch is not functioning.
Old Jan 19, 2024 | 11:57 PM
tyrocksalot
6th Gear
I checked the am1 fuse it was fine. I'm going to start pulling all the 80a out next I guess. All of them look good from the top down. What is am2 line
Old Jan 20, 2024 | 01:12 AM
Yamae's Avatar
Yamae
Both AM1 and AM2 lines supply DC 12V to electronics controls. The AM1 line is getting the DC12V via the alternator 140A fuse. On the other hand the AM2 line is getting it directly from the battery.
Old Jan 20, 2024 | 06:30 AM
alextv's Avatar
alextv
Use a voltmeter as it is the simplest and best time consuming way
Old Jan 20, 2024 | 07:24 AM
xtr3me's Avatar
xtr3me
I have codes B1261 Engine ECU communication stop and B2620 ECU power source. I found this online for B2620... see if this helps
Old Jan 20, 2024 | 02:41 PM
tyrocksalot
6th Gear
So me installing the amp and it popping apparently was just a coincidence. Battery ended up being dead and having some kind of short internally. Thanks for everyone trying to help. New battery and I'm good. And the amp and sub still work. 🥂
PeteLS2K
Mar 26, 2020 04:51 PM
Madoli726
Mar 22, 2014 07:18 PM
T0ked
Nov 18, 2013 01:38 AM
JSwenis
IS - 1st Gen (2001-2005)
Apr 1, 2011 10:12 AM
NAZTY97
Jul 11, 2006 09:08 AM
