How common are "common" problems?
- Screen completely gone/on the fritz
- Air suspension needing replacement / removal
- Door lock went kaput, particularly on soft closing ones
- Anything else I'm missing? Those were the only 3 pointed out
Thanks in advance
- Oil leaks (valve cover gasket)
- Wire harness and other connectors
- Power steering resevoir /filter
- Timing belt tensioner
- Mufflers in rust belt
- Exhaust rust
- Headlight light sensor in the rear
- Oil pan bolts
Screen is fine no issues
Car does not have Air suspension - only ultra luxury models have that, probably best to avoid at this age unless you are willing to pay $$$ if it goes south.
Door Locks - all good. Soft close doors on custom and ultra luxury only IIRC.
no oil leaks at all.
wire harness is fine - but the connectors should be handled with care at this age
Power steering - good, no issues
Tensioner on timing belt - good, you replace that and the idlers when the timing belt job is done along with water pump. Should be done every 90,000 miles
muffers - excellent. My car is Arizona and Washington state, totally rust free, Car Care Nut is correct- the rust belt states are hard on exhaust systems and very pricey to replace with OEM compnoents.
Headlight light sensor - no issues
Oil pan bolts- no issues.
In sum, after 142000 miles my car is on the original suspension and basically nothing has gone wrong with it in except for simple repair of the outside mirror controls which I just did. The build quality of these cars is really off the charts. Look for a good, well maintained example AND GET A PRE-PURCHASE INSPECTION. Many cars at this age will have issues with one or more of the items you mention but a caring owner will have repaired it by now. Deferred maintenance and repairs is a very bad sign in my book.
By the way, my 1998 LS400 is also working like new after 150,000 miles except for cassette player gone bad and one burned out bulb behind the dash, only repairs were valve cover gaskets and upper control arms by a previous owner. Just routine maintenance. Superlative build quality.....
Start looking and fine the best maintained and cleanest example you can find in the color combo you want. Pay a premium for a great example. For a well maintained car 100,000 to 150,000 miles is nothing.
Edit - the cost to fix these issues will depend on whether you can do them yourself, use an independent mechanic, or use a dealer (most costly option). These cars are relatively easy to work on and simple compared to modern cars.
I generally heard it's good to go with 1 owner cars since they know exactly what has (or hasn't) been done to the car?
Haven't bought a used car yet given the market (bought my first car in 2021 and a minivan just this past october, both new) but would definitely be getting a thorough pre-purchase inspection.
https://www.lexus.com/My-Lexus
create an account
add a vin number of a car you are considering as "my Lexus"
- Exhaust rust
- Oil pan bolts
Where did these come from?
- Oil leaks (valve cover gasket) NA - 9 times out of 10 tightening the bolts will stop the leak. The bolts use a rubber integrated washer that becomes brittle over time. Replace the washer and you’re good.
- Wire harness and other connectors. NA
- Power steering reservoir/filter. Easily replaced.
- Timing belt tensioner. NA
- Mufflers in rust belt. NA - I’ve never heard of anyone having to replace a 430 muffler.
- Exhaust rust.?????
- Headlight light sensor in the rear. NA
- Oil pan bolts. NA - Give them a gentle 1/8th or quarter turn.
Thanks in advance
Also NAV. ML stereo pretty much perfect. Subwoofer was changed by first owner.
- doors rotting out around the chrome trim strips (even with Fluid Film application, Tremclad & Bondo for now)
- corrosion around the rear fender (ignoring it)
- corrosion of the fuel tank (had to replace it as it was perforated)
- exhaust & heat shields falling apart (many welds and patches)
- height control sensor linkages get stuck and will damage the control arm attachment points (replaced linkages, attachment tab welded)
- hood release cable seizes (replaced)
- OEM front wheel bearings seems to last around 100,000 miles 'only' in this climate (replaced, rears at around 200,000 miles)
Fully aware that the OEM parts can be quite expensive so will be spending a decent amount on a thorough pre-purchase inspection after I check for the common issues myself.
Original air suspension still working fine.
Telescopic steering wheel motor is weak and needs replacing. Tilt works fine.
Air-con stopped working 3 years ago but will cost half what I paid for the car to fix, so for now it's still not working. Someday soon I'll spend the $2500 to get it fixed (compressor, condenser, etc.).
There are 4 rust spots along the passenger door trim that need dealing with when the weather warms up.
In the 50k miles since I bought her I have had one O2 sensor replaced, replaced the Sub-Woofer, re-foamed the front door speakers, had the exhaust Y-pipe repaired, had both front wheel bearings replaced (only one was rumbling) and have replaced the reversing camera and a couple of parking sensors.
Other than that she's had regular services, with tyres, brake pads, and other consumables replaced as needed.
For a 19 year old car she is awesome and drives superbly.
For the money, I can't think of a single car I would want to replace her with.
i tend to spend more on buying better ones than repairing ones with problems.
Bought it from a dealer, saw its perfect maintenance history on Lexus.com.
door lock actuator (diy motor fix)
valve cover gasket leak (just snugged bolts)
some front seat tears with age (my car sits in the sun)
driver side sun visor malfunctioned causing fuse to blow which blacked out LCD display under odometer - relatively unknown but still seen - solution was disconnecting the electrical connector at the base of the visor
