Wald Duchatelet 2 Nut
Old Feb 11, 2024 | 09:19 AM
JZGa's Avatar
JZGa
7th Gear
Default Wald Duchatelet 2 Nut
Hi everyone, It's my first time buying the aftermarket rim. I was searching for more info online, but without success. I am mainly looking for two things to make sure it will bolt on the car safely.
1. Is this rim hub-centric or nut-centric? The inner bore size of this rim is rather strange, and I can't find a proper size hub-centric ring for it.
2. Is it safe to use the original Lexus wheel nut? Or should I rather buy some aftermarket nuts instead? What brand/size should I looking for?
I've noticed that some of you have had Wald rims on your LS430s. I would be extremely grateful if anyone could share their experiences or answer my question regarding this!
Thanks in advance! I can't wait to fit it on my car! (It's cur
rently undergoing a full rebuild.)
Old Feb 11, 2024 | 11:40 AM
AVSRacing's Avatar
AVSRacing
Just use calipers to measure the inside hub of the wheel and order some hub centric rings. Factory Lexus size is 60.1mm so that's your inner diameter.
Don't use factory lugs, they won't fit, seat properly. You need cone seat lug nuts. Make sure they are Lexus size M12-1.50
Did you test fit the wheels before refinishing them? As they might not even clear your front calipers and you need spacers.
Old Feb 11, 2024 | 12:02 PM
JZGa's Avatar
JZGa
7th Gear
Hi, thanks for your reply!
I did test fit it on the front, and it does clear the front calipers. For the hub centric ring, the closest I can find is with 60.1 inner diameter and 71 outer diameter, and the rim have 73 center bore (I bought the one with 71 outer diameter, but it does not fit snugly inside the rim
Old Feb 11, 2024 | 05:05 PM
Ellesse's Avatar
Ellesse
https://a.co/d/5D8A9kT
Old Feb 12, 2024 | 01:13 PM
AVSRacing's Avatar
AVSRacing
Yea then you just likely need the 73mm od one
Old Feb 14, 2024 | 05:12 PM
DVL5WRK95's Avatar
DVL5WRK95
you can order them online. I have aluminum hubcentric rings that are 60.1 mm - 73 mm
Old Feb 14, 2024 | 05:23 PM
DVL5WRK95's Avatar
DVL5WRK95
these are the ones you need
https://a.co/d/4epWTes
hendrik
LX - 3rd Gen (2008-2021)
Jul 8, 2013 01:51 PM
hapaboy
Nov 8, 2009 06:37 AM
Luxofreak
Apr 5, 2007 07:03 PM
KilaWombat
23
Feb 23, 2007 03:53 PM
