- question about 1jz vvti into pre vvti sc300
- wheels ??
- Will these water pumps work
- Electronic and Cable Trans
- These parts are expensive!!!
- Wheel Poll: Need your opinions!
- Coolant leak...what to do
- Distributor Question
- new rims/wheels...criticize
- new to the 2jz sc3 world.
- replacement needles
- What differences are there between 92 & 94 2jz
- Kaizen motorsports e85 742 rwhp 2jz-gte v160 sc300
- Everyone likes pics!
- Some quick eyelids i made
- Auto>5spd. guys.... how did you remove the "p,n,r,d" off your cluster?
- Just installed S2000 AP1 wheels on my SC4, where's Celine Dion?
- Which Rear Bumper Lip Flows Best With 97+ Skirts?
- 1uzf noise screaming
- Stand alone for sc300 2jz with 1jz head.
- I think i screwed up my distributor timing. help
- Power steering fluid or atf
- New pics of my Soarer.
- help! car wont start
- Sc300 pics and also randomness... Enjoy!
- Alternator light on at idle/over 3000 rpm??
- 95 sc400 swapping the steering wheel.. will this affect pass airbag?
- Center wood trim removal HELP!
- Intake hoses , part number COST??
- Date code 3/93 ecu
- Virginia 5 speed sc300 trying to pass CA smog!
- 2jzgte swap
- SC300 5speedl Cluster swap
- Can you swap your seat heater into a new seat?
- Exhaust questoin. (new to site)
- Daigo Saito 200+ kmh drift (soarer inside)
- Manual transmission temperature
- SC300 heavy doors?
- need some maintenance help
- Part number for tail lamp failure sensor.
- Hey I'm new and got questions and stuff. 92-00 SC400
- FS and WTB posts go in the classified forums only
- FINALLY!!! My new 1999 SC 400
- Noob gearing question
- DIY - Remaking your 92-94 Tail Lights
- clarification quest?
- How does it feel..
- 5 speed transmission swap in NJ/NY area
- Valve Cover Badge
- how much to refill ac ... r12
- key code location
- 93 sc300(auto) issues
- any lexus tech care to help me with price quote?
- wtb oem amp
- Check Eng. and Trac Off Lights on... Help?
- Two tone pink SC I spotted
- Black Interior swap question
- Grrrrr I'm so mad - need advice
- Vent Removal Help
- factory amp
- power steering quick solution
- I bought a SC400
- Wont advise people using lextech's service...
- New to the SC club
- first time under the dc, now got some questions
- Flip out keys?
- (UPDATE!!) put the new rear bumper on today and redid my tail lights.
- another dirty car photo shoot lol
- sc300 99 remote battery
- Problem with ignition i think... please
- Took my rims off, back to factory (pics)
- CEL, ...low idle, ...horrible mileage! HELP!
- Advice on new remote key for sc400 1992
- headers for supra 2jz on sc300?
- Blinking A/C light - only at night
- A/C needs to be replaced, what should I do?
- dimming wire for gauge install
- Car wont start! Need help ASAP!!!
- SC300 midpipe question
- subwoofer amp
- headlight bulb question... ??
- Temp gauge not working. Suggestions?
- Water Leaking On Driver's Side.....HELP!
- started on the paint project today.....pic inside!
- Pic request SC with gold advan rg-d wheels
- How plug and play would it be to swap a na-t in my sc400?
- A Little Driving fun
- sc owners in Southwest Louisiana
- exhaust system loudness
- rare to see,what do You think Guys ?
- Nak drivers side door speaker
- My fix for cluster needles
- SC400 Suspension
- RPM doesnt work after 2jzgte swap
- Kennesaw State University Kappas Host Car Show
- Squealing noise from the engine bay when accelerating?
- Loud squeal AFTER serpentine belt change
- Shift Lock Override Cover
- Sc stories
- Just got a 99 SC300
- So my AC..
- Rolling Shots of the SC600
- Pictures: what was the previous owner doing to my headlights?
- How do I fix this?
- Any 97-00 owners: picture/location of OEM fog lamp switch?
- Got two question for you guys
- Mounting bolts for 97-00 SC fog lamps?
- carbon fiber fun
- cont' 1996 LEXUS SC400 JM LEXUS INSPECTION REPORT!!! WOW
- Oil Leaking from Valve cover?
- SC400 45K miles for $6000 should i buy?
- Calling all lowered/slammed/Vertex Ridge riders
- standard audio system
- Is300 rear caliper fitment, yes or no on Sc's?
- My AEM came in today
- Need Buying Advice
- confused as a gremlin at midnight in a grocery store built over a pool
- SC300/400 owners ... are you still buying premium gas for your car?
- HOw to become a vendor or be authorizes for group buys
- oil pan pain
- egr and maf questions
- New to me 92 SC400
- SC300 GTE or Supra
- Alternator Connector
- headliner removal?
- strange radio behavior
- cd player wiring
- Broken CD and Tape player
- Double Din setup?
- What plugs/wires?
- Lowered on nf210's & seems high in front w/ pics
- 1996 lexus sc400
- Wheel spacers question(s) :)
- A/C Vent trouble and dash
- Date with Smog Check
- Both headlights, at the same time??
- Oh Snap...that looks Japanese!! Let me grab my camera for a quick Shoot...
- Possible new SC, buy at 90-100k?
- Sc/Soarer Awd??
- mini photoshoot
- Stupid Texas Heat!!!!!
- problem with rim center cap
- Dead Instrument Cluster
- SC Interior......
- Help me out
- Best(cheapest) Place to get the vertex front bumper?
- 95 sc400 driverside headlight plug has no power
- SMH 1 W58 Distroyed!! That didnt take long...
- i dont know it its the starter or.....?
- which single turbo is the best to swap with the stock twin turbos in a 1jz-gte?
- spacer for flush fitment? 18x8 (+49 offset) 18x9 (+49 offset)
- My SC400 Daily/Drift machine
- 3A seat bracket questions
- SC300 5speed Clutch questions..
- New Battery?
- Es300 cluster needle on sc300
- Cant find hesitation source help!!!
- New Ground Points (little update)
- anyone else tweaked body after hitting pothole?
- Five Axis S5f...what's your opinion?
- Door actuator wire colors
- SC300 D2S MINI retrofit
- Head Light Restore [Lots Of Pics]
- Radiator help??
- Igniter wire question, please help (Lexus sc 300)
- Sighting: Downtown Atlanta SC
- HELP with coolant leak
- a little sc gathering
- Autocrossing the SC?
- Smoke in my Trunk!
- Varrstoen LM 1.1.2 rims HELP!
- Slammed my car. but 1 small problem...
- What is a 1997 sc400 motor swap worth?
- (PICs)Got my baby out shop, but she's goin back in
- Will a gs300 harness work in an sc300??
- Post Pics of Widebody SCs only THREAD
- Got My Torque back!!! Dyno day.
- headlight
- Here we go again.... One of a kind Work VS-XX
- advice on replacing o2 sensor
- Who wants to play whack a newb with knowlege? Vacuum related
- AEM V2 Start-up Problems - SC300
- Temp gauge gone bad???
- What is the color name for grey leather seats-93 SC 300
- vinyl car wrapping
- Game Change... (lots of pics)
- Bad day....
- brakes lights staying on even when car is off!!
- To all that roll low, how do you deal with scraping?
- Supercharger setup wanted!!
- Smoky Granite Mica SC?
- Photoshoot: SC400 & Acura TL
- Need help!!!!!!
- What Would You Do In This Particular Situation?
- Where to buy crank gear?
- Seat Removal question
- Questions about aftermarket parts? Help!
- Where to buy good quality floor mats?
- Valve Covers Come Off!!
- i wish my sc was red
- Sc300 M/T shifter boot seal pn?
- SC 400 AC fan stuck on high
- sc600 vs caged full race crx
- 10 minutes too late :(
- Secret Hidden Space in SC
- Shifter shaking/shuttering while braking
- Nightmarish starting issues.
- Fs/ 93 sc300 s.fl
- Direct bolt in seat replacement question
- Lots of 1JZ and 2JZ(GTE) SC's being sold lately
- BigBang car pictures (Lots of pics?)
- what should i check? AC questions
- Poopy doopy talking friends
- Resupporting unibody to cut top off
- got bored and fabbed an intake for my sc400
- Quick Question
- I Need CL's Thoughts and Opinions On This
- rubbing on inner fender, its rolled..
- Best year and model to Mod with tight budget? What to do first?
- Some new pics
- Has anyone done this with their exhaust on their SC?
- Driving Sc 400 without power steering?
- 94 sc400 steering wheel
- Alternator? Please help!
- In a fix: '98 dashboard in a '93 SC300. Will a '97+ airbag work?
- something doesnt seem right... or is it just me?
- Removing your crank pulley bolt for the TOTALLY BROKE
- No reverse
- How much should I expect to pay for a gte getrag swap?
- SC400 - New Suspension in 1999?
- will a 98 rear bumper fit on a 95 sc400?
- 2jz converssion
- 1992 SC300 Major Decision
- Problems after disconnecting battery
- Inside Door Handle
- For Sale items go in the classifieds forums, not here
- 1UZ + Nitrous
- The boss is back and bagged on CST Zero 1/Chrome!
- stock parts to kick down?
- What does a 95+ ls400 spare look like?
- Stock 1JZ swap $15,000???
- 2jz-gte built or not? turbo kit choice? opinions?
- My 1 month old SC
- 93 sc300 starter replacement alternative??
- Calling the 1JZGTE and 2JZGTE guys!
- My windows wont work 95 sc400!! help me please
- Which 2 of these 4 wires is for the third brake light
- Fix stock engine or get a reconstructed one?
- Tire Sizes/SC400
- Climate Control Question
