- click, click, starter fix 3hrs, $27 not $271
- Intake for a '98?
- 1jz serpentine belt, no AC but PS, size
- Highway vibration...rear end?
- My Buddy SC400 with Customs exhaust...
- Flex Pipe Help
- Too much for the stock transmission and HG?
- sc300 2jz gte swap
- Fuel pump installation problem pls help!!
- Need urgent help
- ground wire install HELP!!
- AC Scratching Noise
- NEED-2jz gte swap info
- Few preformance product questions
- sc300 spark plug gap question
- Tein test fitting Fujitsubo Exhaust, free? discounted? so cal
- help with bypassing a/c compressor
- Car Died coming to Stop !!!
- My 1jz, How to tell if its a soarer TT auto?
- ***98 Sc Engines Are The Same As***
- ECU questions/help/advice
- harmonic balancer Replacement?
- misfire sc400 (long story)
- Is anyone running a 16lb radiator cap?
- R154 swap, but there's play in the master cylinder
- Car Vibrating on Start up
- Questions and Concerns about na-t
- Fuel pump trouble/DIY replacement
- Fuel Filter Maybe???
- sc300 wont start :( , used to start before I garaged it
- 92 SC400 real-time MPG comp?
- Long story but car wont start, any help appreciated.
- Gave up on the sc400 and picked up an sc300
- which engine swap
- 1jz swap wire question
- Urgent: I'm having a hell of a time dropping my auto, tips anybody?
- Greddy 4 Row Interccooler
- 1jz BOV part # for Blitz or HKS
- w58 tranny question
- Na-t sc...........
- First MoDS in LSD TC
- injen intake on a 98 sc3?
- Battery Light...
- GTE cost.
- 1994 SC400 Radiator replacement
- biggest intercooler with stock bumper
- how to get the specs for a turbo?
- how to remove the linkage from the r154 tranny
- Best cold air intake filter?
- FP ECU Bypass problems
- built tranny any advice or who is good??
- 2jzgte with R154 auto to manual swap question
- ignition breakup or spark blowout ????????
- 1jz oil on plug
- do these injectors fit?
- SC400 motor swap question
- want to go as high as possible on stock twins..
- tac off light is on with check eng, light?
- Sc400 Shutoff When Turn Off A/c
- A/C halp! Interesting...
- Rebuilding 2jz-ge "feel free for any input"
- Carputer setup for real time/datalogging
- Seeking Advice on SC400 misfiring problem.. Codes 13, 14, 24, 31.
- Yet, another R154 related questions regarding the driveshaft...
- Speed Sensor Wiring Question...Gurus step in please!!!
- tach signal wire and best tires for sc400
- need to know all of the parts i need to do a 6speed in a sc300
- fuel filters?
- Should I repair or rebuild my tranny before boost
- Manual Transmission Swap
- battery light wont go away
- questions for drifters.
- Is a loud engine normal for an SC300?
- 1jz-gte on a 99 2jz-ge tranny?
- bucking sc300
- Cam Sprocket Problem
- Serpentine Belt...
- rebuilding and engine questions.
- Guide or info on removing SC400 Trans?
- Will this oil pan fit?
- Water Pump and Timing belt
- Anybody done a manual tranny swap on sc400?
- GT40r vs T67 turbo
- SC400 manual tranny?
- Question With A R154 Supra Trans
- IJZGTE question...kinda weird.
- Crankshaft position sensor
- sc400 air intake question
- TRAC issues still, replaced hose and bled
- CE Light Trac off ?
- Hit the dyno for a baseline [pics]
- IAVC Cleaning
- Spark Plug Question
- how to check engine codes?
- Lsd?????????????????????????
- Supra (MK3) and SC300 1JZ use same downpipe?
- SC300 OBX headers question
- replacing O2 sensors... ?
- New PCV Valve and Hose
- MAF Removal
- clutch issues
- anyone need help doing a 5 speed swap so cal?
- 5 speed conversion for 98 sc300?
- Yep....... Another exhaust question. [SC400]
- SC 400 With a 2jz swap
- help with tach adapter
- HKS Turbo Timer
- sc300 exhaust help
- new exhaust on my 1jz, i hate it.
- So i changed my worn out timing belt
- 1JZ SC300 won't start, need help!
- SC400 hi perf computer chips?
- Sc300 body ecu pinouts
- emissions for patches
- Need help w/ 1jz vacuum hose and turbo sensor
- Where do I recharge my A/C?
- I really need some help
- Headers and X-pipe
- Clutch Trouble (Master Cylinder, maybe?)
- TRAC light always on... help plz?
- Engine codes
- Help Plz.. TRAC light
- Valve cover gasket and sealer.
- I Want A Turbo
- Stall Speed Info, 1jz gte, 2jzgte, 2jzge etc
- SC400 Loud engine moaning vibration burning smell
- Possible plug/wire problem?
- ct26 1jz ?
- Rear seal on transmission
- List of parts to replace before Winter
- Won't go into 3RD GEAR!!
- trying to make contact
- Power steering bypass....
- SC400 swap help....
- head gasket and studs
- Can't turn TCS
- Looking for the 2 polished plates that go under the hood of the sc, one being carbing
- weird stumble with SC400
- SC300 Overheat/Thermostat/Waterpump
- Single T78 almost done...
- jdm 2jzgte o2 sensor.
- 1jz...won't boost over 5 psi!
- Na-t in Oct., but starting Intercooler today/PICS!!
- Strange electrical?
- AC/Engine Problem
- Supra 1jz down pipe
- A couple questions
- Rear-Mount Turbo SC300/SC400
- Time For an Upgrade
- My Sc 300 Won't Start, Help!
- Miss after pressure wash
- Electric fans!
- Sc300 Tb size?
- NEED HELP sc300 STEERING PROBLEM
- superchager
- TURBOXBERTS! Here's my T4 T04 Airesearch T04B Turbocharger BEWARE 56K!!
- JDM 2jzgte Starter
- Ewww, leftovers. :(
- All Swappers
- A343E in sc300 fit question
- SC400 Failed Emissions Very Bad.. HELP!
- Quick question on Turbo
- Supra MKIV NA-t DownPipe onto SC300
- A343E Weight and Replacement?
- They're shiny and they came in today
- Tony performance wins streetdragking event in P.R.
- SC300 Auto to R154 swap question......
- sc300 part number
- A/C never cold after 10 minutes! :(
- How MANy Holes?
- Twin Turbo Question
- Auto 1jz EMS?
- SC300 with 28 inch drag radial or slick
- 273K Timing Belt post mortem......
- SC570? Is it possible or even practical?
- Engine turns off while in movement also lights dimmed
- Breaking Up. Need help from GTE Guru's.
- Are there any 1JZ aftermarket Intake Manifolds ??
- Battery dying overnight
- Need Help Asap
- testing sensors
- 2jzgte swapped question..
- Cam sprocket torque?
- V8-V6 gauge cluster swap info. (tach mainly)
- '95 sc400 - poor performance / getting codes
- Is there a tutorial for changing the clutch?
- 1992 sc400 tranny question
- Location of O2 Sensors (already searched)_
- Water pump missing seal tracks....
- My bucking car keeps bucking
- R154 Q's????
- Pics of my $2700 Sc400
- I could really use some help
- Sc400 issue... smells like gas....
- Engine swap question?
- How do I remove the crankshaft TB sprocket?
- Impossibly high compression results????????
- OMG i dono what to do please help me!
- 1jzgte harness?
- Gated Shifter Question....
- Where does this plug go?
- Boost Controller install question??
- Sc400 engine stutter
- When engine dies.... what now??
- Nice crack in stock manifold
- Valve clearance specs?
- JDM 1UZ? Does it swap into a USDM SC400?
- W58 Year Difference
- 2.5 inch SS exhaust for turbo car?
- Some shots of my custom 3" exhaust w/Vibrant Mufflers
- NA-T or 2jz-tt engine swap
- sc300 shift problem plz help
- Soarer Front Clip
- Reseal or Swap the engine?
- Turbos Whinning?!
- how can i find the 92 knock sensor under the chasis
- Ugh, Another 1j question
- Exhaust Port pic request
- mandrel bend exhaust ???
- After research, i need verfication regarding the R154 swap please.
- Lets talk about trannys! Wooooo.
- Somethings knocking...what is it!?!?!
- Auto 1jz sc300, 5 speed swap?
- Removing Turbo for Smog??
- Custom HKS Hi Power cat back exhaust
- AC recharge
- NA-T or Not?
- 92 SC400 Head Gasket Question
- RPM Meter Dosn't COme?!?!?
- breather on the #2 cylinder cover
- NA-T to-------->JDM ARISTO TT SWAP
- Aristo GTE swap guys...specific wiring question(s)
- 2jz-gte swap SC300 A/C not working
- Oil Filter relocation kit?
- Spark Plugs Gapping
- adjusting new clutch and throw out bearing noise
- Engine Oil Capacity / pressure light
- a/c question
- Engine swapping ideas/questions
- Downforce
- 1jz swap, fuel pump not turning on...HELP
- a/c low pressure side question
- 91 supra a340e into 96 sc4?
- Blitz Exhaust, Intake?
- Stock exhaust size?
- Engine Whinning when i accelerate
- Best way to flare the fender?
- Gonna be a good day
- SAFC Neo wiring
- About to purchase some wheels.
