help with maintainence SC3
Old Apr 2, 2008 | 04:24 PM
edwinbong's Avatar
edwinbong
Default help with maintainence SC3
alright well its time for some maintainence on a 92 sc3. Parts that I'll be changing out are, timing belt, serpentine belt, timing belt tensioner, water pump, cam seals, and crank seals. Are there any other parts that I should also replace? Im going to be ordering the parts from Rock auto, but was wondering if anyone had any preferences or experiences with the different companies/parts.
Here are the options:
Timing Belt:
DAYCO Part # 95215 { Effective Length 45.04 / Top Width 0.99 / Number of Teeth 143**
Camshaft
$15.45 $0.00 $15.45
CLOYES Part # B215
143 Teeth
$17.41 $0.00 $17.41
GATES Part # T215 {Automotive Timing Belt 1" x 45 1/32" (143 Teeth)**
$19.42 $0.00 $19.42
SEALED POWER Part # 222B215
DOHC Engine
$27.89 $0.00 $27.89
GATES Part # 1356849036 {Timing Belt**
$28.99 $0.00 $28.99
ACDELCO Part # TB215 {1" x 45 1/32" (143 Teeth) #88933156**
BELT,TMG AUTOMOTIVE TIMING BELT
$30.79 $0.00 $30.79
Serpentine Belt
DAYCO Part # 5060763
Multiple Accessory
$20.79 $0.00 $20.79
DAYCO Part # 5060760 {Effective Length 76.11" / Top Width .82" / Number of Ribs 6**
Multiple Accessory
$22.79 $0.00 $22.79
GATES Part # K060763 {Automotive V-Ribbed Belt (Standard) 6 Ribs 13/16" x 76 7/8" - discontinued**
$25.79 $0.00 $25.79
ACDELCO Part # 6K763 {K06 13/16" x 76 7/8" #88932743**
BELT,SERPENTINE AUTOMOTIVE V-RIBBED BELT (STANDARD)
* Non-stock item--shipping delayed up to 12 business days
$27.79 $0.00 $27.79
Timing Belt Tensioner
KOYO Part # 1350546041 {Timing Belt Tensioner**
$31.89 $0.00 $31.89
BECK/ARNLEY Part # 0241231
Timing Belt Tensioner, 1 Per Car
$39.79 $0.00 $39.79
GATES Part # T43100
Cam. Tensioner Hyd. Assy., Timing Belt Tensioner
* Non-stock item--shipping delayed up to 2 business days
$41.79 $0.00 $41.79
ACDELCO Part # T43100 {No Pulley Attached #19143319**
TENSIONER,TMG BELT CAM. TENSIONER HYD. ASSEMBLY; TIMING BELT TENSIONER
TENSIONER,TMG BELT CAM. TENSIONER HYD. ASSY.; TIMING BELT TENSIONER
$44.79 $0.00 $44.79
ACDELCO Part # T41208 {#19143288**
TENSIONER,TMG BELT TIMING BELT TENSIONER
Water Pump
AIRTEX Part # AW9256 {discontinued**
(w/o Turbo, 11 Fastener Design)
$50.79 $0.00 $50.79
AIRTEX Part # AW9411 {discontinued**
(w/o Turbo, 10 Fastener Design)
$59.99 $0.00 $59.99
A-1 CARDONE Part # 571456 {[Water Pump] Reman.**
$54.89 $10.00 $64.89
BECK/ARNLEY Part # 1312217
11 Bolt
$82.79 $0.00 $82.79
BOSCH Part # 98152
11 Fastening Holes; OE REPLACEMENT
$78.79 $0.00 $78.79
BOSCH Part # 98176
10 Fastening Holes; OE REPLACEMENT
$89.79 $0.00 $89.79
CARDONE SELECT Part # 5543140
$115.79 $0.00 $115.79
ACDELCO Part # 252268 {#12494017**
PUMP KIT,WAT
$138.79 $0.00 $138.79
Cam Seals
TIMKEN Part # 710436
$4.26 $0.00 $4.26
BCA/NATIONAL Part # 710436 {Oil Seal / Acrylates / Shaft Size=1.594" Housing Bore=2.067" Outer Diameter=2.075" Width=0.236"**
$6.01 $0.00 $6.01
Crank Seal
TIMKEN Part # 229005
Viton; Rear
$10.26 $0.00 $10.26
BCA/NATIONAL Part # 229005 {Oil Seal / Fluoroelastomers / Shaft Size=3.543" Housing Bore=4.331" Outer Diameter=4.343" Width=0.472"**
$13.63 $0.00 $13.63
TIMKEN Part # KWK99181
Kwik Sleeve, Optional Repair; Front
$17.32 $0.00 $17.32
BCA/NATIONAL Part # 99354 {3.540" x 3.546" x .906"**
Redi-Sleeve
$34.99 $0.00 $34.99
CORTECO Part # 17353 {Engine Crankshaft Seal**
Rear; Molded Rubber; 1-Piece
* Non-stock item--shipping delayed up to 5 business days
$19.29 $0.00 $19.29
TIMKEN Part # KWK99354
Kwik Sleeve, Optional Repair; Rear
$35.79 $0.00 $35.79
Thanks for all or any help in advance.
Old Apr 4, 2008 | 03:07 PM
Fireblaze's Avatar
Fireblaze
My suggestion is putting in OEM parts.
Old Apr 4, 2008 | 09:44 PM
SCoupe's Avatar
SCoupe
CL Folding 25,000
Agree x 2
There is no reason not to go with oem parts from ordered from Carson. The 2j is a remarkably well built and reliable engine. Particularly with seals and the timing belt.
Old Apr 15, 2008 | 10:40 AM
STRONG SC's Avatar
STRONG SC
serpentine belt is still new. no need homie
Vito 06430
Aug 20, 2012 09:59 AM
rennwerkes
Jul 29, 2011 01:53 PM
RGP
Apr 29, 2011 08:41 PM
swat1727
Dec 11, 2008 12:44 PM
Red Bully
Aug 16, 2008 10:21 PM
