sc300 w/ 2jzgte Running lean
Old Mar 28, 2008 | 05:50 PM
W1d0wMaker's Avatar
W1d0wMaker
Default sc300 w/ 2jzgte Running lean
I have a 93 sc300 with the 2jzgte swap, and I am running lean. the no1 o2 sensor is reading lean, so it is working, i have an aftermarket fuel pump and have done the 12v mod. Everything seems to be working except i am running lean, and cant figure it out. the only modifications i have done performance wise is an intercooler kit, and fuel pump. can someone please help me figure it out, or give me some trouble areas to diagnose
Thank you,
Josh Graham
Old Mar 28, 2008 | 06:17 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Old Mar 28, 2008 | 06:20 PM
LexusFTW's Avatar
LexusFTW
how do you know you're running lean? do you have a wideband installed? are you throwing engine codes?
Old Mar 28, 2008 | 06:22 PM
W1d0wMaker's Avatar
W1d0wMaker
I am using an air fuel ratio guage tapped into the o2 sensor wire
Old Mar 29, 2008 | 07:54 AM
ucfa4's Avatar
ucfa4
Im having the same problem. Im not getting any codes but when i pulled my plugs they were as white as the day that i installed them. Im thinking about just buying an apexi fuel controller.
Old Mar 29, 2008 | 08:50 AM
W1d0wMaker's Avatar
W1d0wMaker
thats where im at,
Old Mar 29, 2008 | 09:01 AM
W1d0wMaker's Avatar
W1d0wMaker
I just dont wnt to spend the money, Economy sucks here right now so money is scarce
Old Mar 29, 2008 | 09:11 AM
TTSC3's Avatar
TTSC3
Don't use that narrowband reading to get your A/F. Get a wideband, or go to the dyno for a little bit, just to see where you're at.
Old Mar 29, 2008 | 11:52 AM
LexusFTW's Avatar
LexusFTW
Really? A narrowband a/f gauge won't tell you anything besides whether the car is in open or closed loop. Throw that thing away and get a wideband o2.
Old Mar 29, 2008 | 07:06 PM
Gunnar's Avatar
Gunnar
I'm with everyone else. Get a wideband ASAP.
Old Mar 29, 2008 | 07:13 PM
Dew23's Avatar
Dew23
What ecu are you running and yes get a wideband.
Old Mar 30, 2008 | 04:30 PM
W1d0wMaker's Avatar
W1d0wMaker
the stock 94 supra tt a/t ecu, dyno 50 mi away, any suggestions on an affordable wide band
Old Mar 30, 2008 | 04:38 PM
W1d0wMaker's Avatar
W1d0wMaker
looking over the vaccum diagrams, seems I am missing a vaccum controler right before the fuel pressure regulator, also when i remove vaccum before the fuel pressure reg, it runs rich at idle, and lean in boost, so unless someone says otherwise I am going to assume that missing this piece is not helping my fuel problem. i am also seeing some open vaccum hoses elsware not sure where they go, so i am currently going over my diagrams. I am also using the factory sc300 MAF sensor, not sure if that is causing any problems, but according to my diagrams and my research, the supra uses the o2 sensors to controle air fuel, the MAF is pretty much just there to be there. So please lend me your knowledge!
Old Mar 30, 2008 | 09:11 PM
Dew23's Avatar
Dew23
Is the motor us or jdm spec the maf is wrong if us spec jdm uses map sensor.
Old Mar 31, 2008 | 09:37 AM
W1d0wMaker's Avatar
W1d0wMaker
its the jdm aristo motor
