95 sc 300 8000 miles tranny problem
Old Apr 10, 2008 | 05:14 PM
tedd930's Avatar
tedd930
Registered User
Default 95 sc 300 8000 miles tranny problem
I just bought a 95 sc 300 with only 8,000 miles on it !! the car is new!!
i noticed that it wasnt going into od after pushing od button.. still no luck
dealer says i need a throttle posion sensor to further check the problem.
does this have anything to do with the tranny and will this fix the problem?
please respond. also looking for a good lexus shop in south fla area
thank you..
Old Apr 10, 2008 | 05:48 PM
rominl's Avatar
rominl
exclusive matchup
welcome to clublexus
i moved your thread to the sc300/400 specific forum for more support
Old Apr 10, 2008 | 06:14 PM
Luxor's Avatar
Luxor
With 8K miles your car should not have any problems with it. But you should check to see if the button is even has a connection and check fuses if applicable. If you do not have a check engine light on then I would not worry about the TPS sensor.
Old Apr 10, 2008 | 06:35 PM
neurocity's Avatar
neurocity
Not quite my tempo
You got a title with that...cause 8K and a tranny problem seems fishy.
Hope your cluster hasn't been replaced.
Old Apr 11, 2008 | 06:05 AM
RyanV's Avatar
RyanV
Was the car in a flood? The TPS must be another issue you are having.
I'd get a second opinion on this one.
Old Apr 11, 2008 | 06:58 AM
plex's Avatar
plex
1UZFE/2JZGTE
With 8K miles this car was probably sitting for a long time somewhere.
Old Apr 11, 2008 | 08:09 AM
RyanV's Avatar
RyanV
That's right, and it could've got ants in the wiring or mice rats etc...
Have you pulled the shifter to see what the wiring there look's like? It's easy.
Old Apr 11, 2008 | 02:09 PM
FormosaSC's Avatar
FormosaSC
did i read this right? 8000 original miles? i really dont think so... but if so you have a time machine
n8doggdago
Sep 16, 2008 05:04 PM
BlackSC300
May 12, 2007 01:43 PM
Timmyc
Performance
Sep 1, 2006 07:22 PM
IrockLex
Feb 17, 2004 08:44 PM
