- Should I buy it?
- my trac light is flashing
- 18 inch staggered wheels
- Battery drain on radio circuit ? Not radio what else is on this circuit
- 2005 IS300 with 60,000 Miles!!
- Problems - P0171 P0174 :/
- Engine Removal(WITHOUT or WITH Tranny)
- IS300 wagon auto good for HPDE?
- Lexus IS300 Sportscross manual swap?
- Slow Oil Leak 2003 IS300
- CEL code clearing
- window problem
- 100,110 2jzge vvti from the salvage yard, Ran good. What must i replace before dropin
- carrier bearing
- Help
- Wierd noise from back when driving
- Rmm Lip
- Heater core coolant leak
- Keep it or Sell it?
- Is300 starting problems
- Is300 maintenance schedule
- Security Light Flashing...Thought was fuel pump
- 2003 is300 oil leak (valve cover gasket already replaced)
- in case someone is interested....
- Advice on straight pipe exaust for my 01 is300
- Need Help Car Stall when i brake
- IS200 Front Crank Seal Replacement
- Losing oil but don't know why?!?!?! Help Please!!!
- Clock has no characters and buttons not lighting up.
- Browsing old threads?
- Lexus UK's Search for Oldest IS 200 in the British Isles
- Need help deciding on if I should purchase this 2005 is300
- Weird noise comming from under car during acceleration/RPM in drive/neutral
- Auto-man swap plus 2jz gte swap
- AC controls - temp reset?
- Lexus is 300 2004 auto
- Weird Shaking When A/C is on during Idle
- Potential new owner problems
- Oil Leak in Valve Cover Gasket?
- power steering fluid leak
- engine re-timing procedures for Lexus is300
- Lsx swap question
- New member saying hello
- Synthetic Oil?
- New to 1st gen
- Misfire cylinders 4 and 6: wet plugs
- Short throw shifter question is300
- Need advice on buying IS300 (P0300 Code)
- Seat covers
- 2003 Lexus IS300 AC issue
- Hello everyone just joining the first Gen crew
- Offset questions to make wheels flush.
- intake manifold or aluminum radiator
- WorksBell Paddle shifter install & review
- Why am I getting only 137 Miles on a FULL TANK on my 2001 lexus is300
- Car wont start
- First impression: Dupli color vinyl & and carpet paint
- help identifying wires
- Trouble with CEL code and diagnosis
- Engine Won't rev past 4k, Trans hangs - What's going on?
- New member check out the is!!
- Completely lost misfire issue
- how to tell if H&R lowering springs are fake
- Are there any IS 1st Gen with full leather seats?
- 01 Lexus is300 catalityc glows red and car looses power
- Buying 2001, Need Help
- Help
- Purchased 2005 is300, found out car has mainly used regular 87 instead of premium
- Need help
- TRD side skirts install
- Awesome Turbo 1st Gen IS 300 Build Threads You Need to See
- Need Lexus is300 manual engine!
- 300 is
- Transmission
- Mirror connection
- Tuning,runnig rich HEEEEELLPP
- Srt Stage runnig rich
- Strange Knocking
- Is this noise normal? I don't remember normal.
- Need some serious help please
- for sale goes in the classifieds, not here
- Looking for a Crank Trigger wheel in Toronto.
- '04 IS300 Stuck in Defrost
- fuseable link blown
- dyi head gasket replacement
- disconnected the positive battery terminal while car was running
- Dash Lights Not Working
- Is300 swap
- o2 spacer gone wrong. Help!
- Lexus is300 steering wheel
- 2004 IS300 SD (TCM) Wheel Color
- Catalytic converter help please
- RMM carbon fiber splitter
- 2004 IS300 CD Changer Error 4
- '04 IS300 Error 4 CD Changer
- IS300 exhaust
- "BLACK ROSE" Liberty-VIP IS300 - Aidan B.
- ISO: Stock IS300 Front, sides, rear bumpers and skirts, Xchange for polyurethane kit!
- 2003 lexus is300 sportcross aftermarket wheels
- Traklite wheels?
- 2002 Lexus Is300 Sportcross for sale
- Wald Fender Flares ? Aiming to widebody my is300
- Props to Alchemist
- Alternator is on its way out.. help
- IS300 youtube gold!
- crank won't start
- Need Advice
- Rear View Mirror Help
- Oil leak
- Do Lexus have cracking dashboard problems?
- Shudder at 40 kph
- How to make my stock is300 quicker..
- Headlights Only Work if Car is Running
- Vacuum line diagram for 1st gen IS300
- needing help with a driveshaft issue please?
- 01 IS300 Worth with a blown head gasket?
- Passenger fog/headlight out
- Help fixing my AC!
- Engine air and evap hose diagram
- Horrible cold start misfire problem/fuel dump
- Lexus LX470 Speakers
- IS350 S - 2005 - questions (Firmware/Nav)
- True or Faulse....
- Joe Z Intake
- Lexus is200 doors handle removal
- 2003 Is300 p0441 trouble code, ABS light on, and trac control light flashing
- 04 radio amp trigger on
- p0446 vent malfunction troubleshoot
- 2005 Lexus IS300 all season tire recommendations
- p0420 & p0420p Codes on 03 Sportcross
- Wont stay running
- Help! harmonic balancer bolt
- Harness question
- Did the IS300 and MK4 Supra ride on the same chassis?
- 02 IS 300 Limp Mode
- Will a is250 seat fit in a is300?
- If my clutch is going bad, can I still practice manual?
- Rear Bumper Removal
- Hose
- Center Console
- Lexus IS200 2002 speedo odo not working, fuel needle jumpy
- Replace front indicator lights '03 IS300
- Fender and front bumper busted
- wheel and tire fitment
- Lost master key what is the easiest cheapest fix
- 04 es33 on hyundai staggered wheels?
- shifter wont lock into the park slot- keys wont release from ignition
- Dash light
- IS300 sedan front bumper interchangeable with the sportcross?
- Steering rack tensioner bolt same as GS?
- installing fuel pressure regulator
- 2001 IS300 throttle assembly
- Is200 loom under steering wheel
- for sale belongs in the classifieds, not here
- Car bouncing in reverse
- 2003 Lexus IS300- Tune/ Engine Rebuild HELP
- My new IS 300! 2001 auto with 56k
- 2005 is300 Newb to the forums!
- 1st Gen is300 throttle response
- Headunit CD malfunction - could it be wiring?
- A650E slow Change Up when Cold
- Check Engine Light and Tracking Off Flashing
- 04 IS Air Servo Motor Install
- Battery cable
- Battery cable gauge
- The best combination of 18"
- Spit & Sputter after negative unhooked
- 2005 IS300 No Crank, No Start
- Clock and outside temp not being displayed on the a/c cluster
- 2001 IS300 VVT help!
- Airbag Light Resistor Help
- 05 IS300 check engine light, VSC, and trac off lights on
- Control arm help
- newbie to the forum.
- turbo is300 etest.... where to get it done...
- Rebuid is300 engine need tips...
- Other Toyota headunits in an IS?
- 05 is300 not cranking after new plugs and wires
- 01 IS Won't rev past 4000
- 1jz downpipe for is300
- DIY: is300 steering rack replacement vid
- IS300/2JZ recommended mechanics?
- What IS300 Body Kit?
- Newbie Here
- All FS & WTB go in Classifieds Section Only
- IS300 Burning oil
- Error code P0161, Lexus IS 300, bad o2 sensor, bank 2 sensor 2
- 03 is300 limp mode after about 10minutes with codes p2121 and p2127
- P0012 help!!!!
- Back speakers
- Error VSC + TRC + ABS + hand brake on IS300
- Water Drip?
- 2002 is300 performance help
- Need new control arms, reputable vender?
- New IS300 owner clunk/lurching when shifting from park
- Does anyone have any idea what's wrong with my car?
- Is300 2001
- Head unit wiring. No power
- My New I300. Traded my NA Miata for it. Worth it?
- Protective cover for dogs in rear seats.
- Lexus is200 sounding weird
- Ecu Question
- Fuel gauge not working
- wanted
- I must be crazy, need help fast
- JDM swap
- Few questions
- Hello
- Joined the club my 3rd time over, this time with a sportcross!
- White Smoke coming from under hood - Dealership can't find any issue with vehicle...
- NEW MEMBER - AC Compressor Problems - Bypass?
- Need help on my Aristo swapped is300!!
- All FS & WTB go in Classifieds Sections Only
- intermittant die and restart on highway any ideas
- New member, tires wearing on lettering, ???stumped
- Sanding/Painting chipped bumper
- looking for a 12v constant for a dash cam
- Regulator or something else?
- P1346 Variable valve timing sensor malfunction
- Just bought an 04 IS300 Sport Design...pics inside
- Rear defroster not working
- Serviced IS200, now have engine error codes
- Is the hps air intake good for my Lexus is 300 I'm looking to buy one for my car
- Trying to find a 5speed is 300
- Waving RPM - last hope
- Bad to floor it?
- Power up a 02 manual Cluster?
- wet car
- No head lights
- Lexus club / car meets
- Tanabe Madallion Touring cat back W res delete
- Help with these wheels I want to buy
- NA Supra Engine/Trans Swap?
- 1jzgte swap with auto trans
- 2002 Lexus is 300 Turbo
- How Bad is this Harmonic Balancer?
- IS300 stock navigation not working, Can someone help
- Introduction
- Need help
- Front wheel sound need help new is owner
- Offset and wheels size help for a 2002 Lexus IS 300!!!
- Tail light warning stays on, even though all lights are working. Help please
- CD Player died out
- third brake light inlays for lexus is300
- Looking to get in contact with all pres or vice pres of each sxe chapter.
- My Lexus IS250
- Need help to name a part
