WorksBell Paddle shifter install & review
Parts:
Bee*Racing steering wheel
WorksBell Paddle Shifter NEO
Install is pretty straightforward. Remove the old steering wheel.
Install the hub. The paddle shifters install directly between the hub and the wheel.
Important note: I translated the japanese wiring, and North American IS300s follow the Aristo /GS300/400/430 wiring diagram. NOT the Altezza.
You put the left, right, and ground wire pins into the supplied plug, and plug it into the clockspring as you are bolting the paddles and the wheel to the hub.
Personally I love paddleshifters. I never liked the format Toyota/Lexus did with the e-shift buttons.
It looks awesome
It looks awesome
Update after a nice 150 mile roundtrip daycation to my friend's house. The paddles seem to respond faster than the buttons in manual mode. Whether that has to do with better contacts for the ground signal to trigger, or by design... maybe the e-shift buttons are built a certain way so that you need a certain amount of force for the contacts to trigger, or that with age the buttons have worn out a bit...
Either way, the paddles make acceleration from a stop a lot more fun lol. Same for highway onramps and offramps, and downshifting to pass.
Just adding this simple wiring diagram I made. This is of the white plug that connects to the factory clockspring. This is how all IS300s are, and GS300 GS400 GS430s
**NOTE** follow this as you install the left, right, and ground wire pins into the white plug
Is there anyway to prevent the transmission from automatically shifting at redline so you can turn more RPMs?
Will
Yes I have manual mode. I am planning to run a stand-alone eventually, but not yet.
I am actually a Lexus tech, but no one at my shop has messed with modifying the early cars so they don’t know how to prevent it from automatically upshifting in manual mode.
Will
Will
that's weird I just drove my 2GS and I be banging gears on red line till I shift. I know the lowest in manual mode is 2 gears maybe you just have some weird rev limiter.
I didn't bother to take pics of the install of the hub or steering wheel because installing those pieces are no different than any other hub and wheel install. You can search for aftermarket steering wheel install here on clublexus or my.is or even youtube and it's the same process. IS300, GS. SC, LS, etc
The kit includes the paddles, hardware, and a hub. So the good news is you don't need to buy a hub separately.
This is WorksBell part # 528NEO. This kit is plug and play on Altezzas/IS300s and 2nd gen Aristos/GS3/4(3)0s.
Oh and to make aftermarket horns work 100% of the time, I used a WorksBell grounding ring between the hub and the paddles then wired the horn to ground to it. I don't remember if the ring came with the paddleshifters, or it was something left over from my Rapfix QR I put in my SC300.
I can't recall if I had issues with the MOMO button working, but when I replaced this wheel with a C-ONE and put in a Personal horn button the horn wouldn't work at all. The button was trying to ground to the paddles and since it's anodized it's non-conductive. What I did to fix this is I connected (wrapped) a 2in ground wire from the horn ground prong and put a slip fit connector on the other end. This connects to the grounding ring
Last edited by 1997Soarer; 11-27-19 at 02:46 PM. Reason: Added how to make horn work
You should probably search for that answer on my.IS.
HKB makes a hub for the JZA80 Supra, JZZ Soarer and the JZS147 Aristo that has cruise control buttons on it, but I actually tried to see if that would work on my IS300 so I could have cruise and aftermarket paddleshifters... and found out the older cars use an analog control system while the JZS160 Aristos and JCE/SXE/GXE Altezzas are digital.
I searched for a bit thinking maybe some company did make something but didn't find anything. That was in the summer of 2017. I've seen some smaller stick-on touchpads that mimic cruise stalks come to market for other cars, but so far nothing for older Toyota/Lexus cars of our era
Sleep (03-28-22)
