IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Car wont start
Old Aug 21, 2017 | 12:18 AM
Evanner's Avatar
Evanner
Default Car wont start
I have an 03 IS300 and after changing my battery my car all of a sudden wont start.(Coincidence?) I have already put in new alternator (due to over charging), plugs, wires, coils and valve gaskets. The plugs were soaked in oil which I thought was the issue but still wont start. Car will turn over but horn and radio wont work. Already checked all fuses and are in good working order. THOUGHTS?!!?
Old Aug 23, 2017 | 03:02 PM
Lexusdk's Avatar
Lexusdk
You should perform a voltage drop test. Its possible that there is a bad connection somewhere. Check you battery terminals and post. Then check the ground cable to the chassis for any corrosion build up. If there is any, clean it off with some sand paper and try starting again
Old Aug 28, 2017 | 12:25 PM
ISBeast300's Avatar
ISBeast300
when you unlock it, and put your key in the ignition, look at the dash- is the "security" light still flashing or is it off?
if it is still flashing then your car has gone into lock out mode
schwartzyd
Dec 4, 2017 05:25 PM
1genls400
May 17, 2008 05:21 PM
Xterminate
14
Sep 23, 2007 02:10 PM
eatmorchic
Dec 29, 2006 08:24 PM
indypwr
Nov 15, 2004 03:22 PM
