'04 IS300 Stuck in Defrost
Problem. My fan position controller **** doesn't work. And the climate controller does not work. The fan power does work. All 3 of the buttons, rear defroster, circulation/outside intake, and ac button all work. My fan is stuck in defrost and is stuck on max cold or max hot, if i play with it for a while it will switch between the two.
I checked and replaced the servo motor. My fuses are also good. I am at a lost for what might be my problem.
