Any DIY on cooling flush?
Subscribe
Aug 20, 2018 | 07:58 AM
hi guys i have 07” IS350 and i am the only original owner, when my car hit 100k miles the alternator fail, and i just replaced along with a brand new drive belt and since i doing the repair i go head did the spark lugs replaces, oh man this is the easiest spark lugs i ever replaces in V6 engine, it took me about 30 mins to do the plugs, ok back to the title i just wondering anyone here have done the cooling flush on the IS350? If you did is there any DIY? Is it hard to do? Thanks in advance
Reply 0
Aug 20, 2018 | 08:34 AM
https://www.clublexus.com/how-tos/a/...adiator-362361
Reply 0
Aug 20, 2018 | 01:09 PM
Quote: https://www.clublexus.com/how-tos/a/...adiator-362361
thanks but that look like the isf engine? Is it the same location drain plug on the engine block as the IS350? My dealer quote me $180 plus tax, is it the good price or i can do it myself to save me a out $150? Thanks
Reply 0
Aug 20, 2018 | 04:22 PM
Did coolant flush on my 250 few days ago at 125xxx km (77K miles). My mechanic suggests to replace it earlier than Toyota Lexus maintenance schedule recommends which is at 160XXX km.
He had seen on multiple occasions cars with blown head gaskets, water pump failures, overheating, thermostat problems, coolant leaks. corrosion and damage to radiators simply because coolant was neglected or never replaced. The coolant becomes more acidic over time and loses its cooling and rust prohibiting properties, causing corrosion and likely overheating.
It took around 8.0 Liters of Toyota Long Life coolant and the car was done in 50 min, I paid $170 bucks for the service.
Reply 0
Aug 22, 2018 | 11:15 AM
https://youtu.be/0uImhl8XzB0
first couple of minutes, I have the part where fluid is flushed.
Reply 0
Subscribe
