Central locking issue (Please help)
Old Aug 31, 2018 | 12:36 PM
Luciano250's Avatar
Luciano250
Default Central locking issue (Please help)
Hi guys, would like to ask you for a help with following issue. My IS250 *2007 is opening only drivers door. No matter if you push unlock button on key fob, or pull drivers handle, or passengerīs handle, or push the button inside on window panel. Car always open just drivers door. When you mechanically open other doors ( push the mechanic button near handle to open) and you try to lock the car no matter which way, it will lock all the doors. The issue I am experiencing is with unlocking only. When you try to pull passengerīs handle on locked car, it will unlock the driverīs door and I can hear clicking sound of door actuators, but nothing happens. Tried to connect on diagnostics but there is no DTC. I have replaced all lock mechanisms ( I got them from another is250) still the same issue. Any ideas? I have one more IS250 so I can work switch parts between them to try if it helps, but I think I tried everything with the same result.
Beyondx4
Dec 29, 2023 12:39 PM
elsonido
Feb 27, 2018 03:57 PM
Lohus
Mar 22, 2015 01:13 PM
CJ7Hokie
Apr 9, 2013 07:22 PM
DOHCZ34
Nov 14, 2009 10:39 PM
