P0420 VSC Light & Wheel Speed Sensors C0200, C0205 C0215
Hey guys,
Here's a little backstory on the 2006 Lexus IS250.
I purchased it July of 2017 with 87,000 miles on it. I just recently hit the 100,000 mark and have had 2 major repairs in 12 months and now I have a new series of codes coming in so I want to get some feedback from the community. Trying to figure out if this car is worth saving or if I should count my losses (even though I still owe $5,000 on the car).
The first major issue I had was a water pump malfunctioning which led to some fluid leaking. This was back in October of 2017. Total repairs were roughly $800 and that included parts and labor.
In May, I had two codes pop up:
P0014 (Camshaft Position 'B' Timing Over-Advanced or System Performance Bank 1)
P0022 (Camshaft Position 'A' Timing Over-Retarded Bank 2)
After getting this inspected it cost about $1,400 in repairs between running diagnostics and repair.
My most recent problem is what just appeared and all at once:
C1223 (Lamp Brake Warning Output Circuit Failure)
C0215 (Left Rear Wheel Speed Sensor Signal Malfunction)
C0205 (Left Front Wheel Speed Sensor Signal Malfunction)
C0200 (Right Front Wheel Speed Sensor Malfunction)
C1201 (ABS Inlet Valve Coil LF Circuit Short to Ground)
P0420 (Catalyst System Efficiency Below Threshold Bank 1)
Does anyone in the community have a guess as to what the key issue would link all these codes sparking at once? In addition, I just recently moved to Nashville, Tennessee and no longer I have a mechanic I trust in the area. Does anyone have a mechanic in Nashville they would suggest or a specific auto shop they would recommend for Lexus models?
I too have the C0205 (Left Front Wheel Speed Sensor Signal Malfunction) issue wih my car. I changed the wheel bearing + hub assembler for the front left wheel, but this one code still remained, Anyone know what needs to be done to wipe this code?
jrmyrnsm
GX - 1st Gen (2004-2009)
06-29-19 05:03 PM
