IS 250, Changed spark plugs? VSC light on
Old Aug 10, 2018 | 02:25 PM
allenswift's Avatar
allenswift
Default IS 250, Changed spark plugs? VSC light on
I just changed the spark plugs on my 2008 IS250 which has 82k miles on it. Now the service engine light for code P2017 is on as well as VSC light and Traction light are both on as well. I own auto repair shops and have done tons of tune ups so the ability to do it is not the problem. We have pulled the intake 3 times since to make sure we wasn't missing anything and we didn't. It is a solid code and wont let me clear it at all, when I try to clear codes the only light that will change is the traction light will go off for a split second and back on again.
And prior to doing the simple plug swap the car has never had the check engine light on. Any suggestions would be appreciated.
Old Aug 10, 2018 | 02:57 PM
MikeFig82's Avatar
MikeFig82
Since it's a runner issue check this threads out:
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/895578-p2009-possible-solution.html#post10265772
https://www.clublexus.com/forums/is-2nd-gen-2006-2013/894619-intake-manifold-valve-issue.html#post10265832
Old Aug 10, 2018 | 09:21 PM
markjustus's Avatar
markjustus
sounds dumb but, is the MAF sensor plugged in all the way? along with accompanying vacuum hoses?
Source: i make bonehead mistakes sometimes.
Old Aug 11, 2018 | 10:32 AM
zoomee99's Avatar
zoomee99
I just changed my plugs too and got the same code. Forgot to reconnect the hidden connector under the rear of the intake. All the experience in the world, you are still human, like me.
Old Feb 22, 2021 | 11:11 PM
Donmeyer's Avatar
Donmeyer
I did the same thing once before when changing spark plugs. Forgot a small hose in the back.
emadrigal
Mar 3, 2013 03:38 PM
jroy3221
Nov 25, 2012 03:36 PM
NastyIS
Nov 5, 2011 04:48 PM
wopdud
Feb 14, 2011 01:13 PM
incharlest
Jan 19, 2009 06:38 PM
