06 IS250 Wont Crank
Subscribe
Jan 11, 2019 | 08:45 AM
Hey everyone I'm new to this forum. So yesterday i ran into some car trouble. Ill explain what happen, I went to go move my car and everything worked perfectly fine. A couple of hours later i needed to go run some errands and my car wouldn't crank. All the lights turn on my push start turns green everything in the car works but no crank. The main culprit that I have in mind would be my starter, what do you guys think? If it is the starter is there a DIY thread wouldn't mind tackling this job down myself.
Reply 0
Jan 11, 2019 | 08:51 AM
Try the battery it may not have enough juice to crank. Mine went out out one day to another recently. Take it to the auto parts store to get tested. Then go from there, and be careful with reverse polarity installing. The last thing is you want is blowing the fusible link on the car. Also your tools shortening to the body, or similar fashion.
Reply 0
Jan 11, 2019 | 09:12 AM
thanks mike, once i get home from work that will be the first thing that i will check. Hopefully that works if it doesn't ill move on to the next thing.
Reply 0
Subscribe
