VLAND Headlights fuze
Hi all!
I'm new here at ClubLexus but I've been a lurker for awhile before I got my car.
Just wondering if anyone here currently have the vland headlights?
I just installed mine but I couldn't figure out how to plug it in the fusebox.
It says just remove the 10 fuse on the driver's side fusebox but once its plugged in there is just no way to close the fusebox.
Just wondering if anyone has found a solution for that.
I have a 08 Lexus IS350 if that helps.
I think they are simply tapping off a 12v source in the fusebox.
there should be a way to have the wire pass through the cover somehow.
more:
https://www.clublexus.com/forums/is-...ming-soon.html
more:
I fixed it last night.
There was a part in the fusebox thats blocking the fuse for the headlights so I just trimmed it down a bit and put electrical tape on it just for more security.
Then I drilled a tiny hole on the side of the fusebox cover and put the cable through it so I can close the fusebox and I just sealed it off with some electrical tape as well.
Sounds sketchy but it works lol
MrHarris (05-16-22)
Turang
01-21-21 04:17 PM
joedaddy1
07-15-16 12:46 PM
