Fuel Leak Help
Old Feb 2, 2019 | 05:14 PM
aimer100's Avatar
aimer100
Default Fuel Leak Help
Hello Everyone,
This is my first post on CL so please bear with me. I've experienced an issue with my 06 Is 350 which may or may not be related to the fuel delivery pipe recall work that was done on my car. Here's what happened:
I was on a well paved 2-lane freeway with minimal traffic, and drove "spiritedly" on my way to pick someone up from the train station (Solana Beach, California). After picking up my passenger, we headed back home driving regular speeds, until my dash lit up with CHECK VSC, CHECK ENGINE, STABILITY CONTROL... I smelled gasoline coming inside the cabin and immediately lost power to the accelerator. I used the car's momentum to pull over and noticed a huge gasoline leak under the car. The engine was also steaming hot. I called a tow truck and now the car is parked outside my apartment.
Now, I have no idea what the issue could be. It could be leaking fuel injectors, but that doesn't explain the excessively large puddle of fuel or the steaming engine. I don't think it's related to the cooling system, because my coolant reservoir is full. My engine cranks but doesn't start up. Each attempt of starting the car leads to more fuel leaking under the car. My car did have a leak before this due to a loose fuel pipe bolt but I fixed that and I don't think it's related. Maybe the recall work wasn't done properly... Please offer any suggestions.
Thanks
Old Feb 2, 2019 | 05:29 PM
Nad1370's Avatar
Nad1370
Well, i would find where the leak is coming from.
I'm guessing one of the fuel line with a quick disconnect came off.
Maybe it wasnt "Clicked" in well enough and worked itself loose.
Old Feb 2, 2019 | 05:50 PM
MikeFig82's Avatar
MikeFig82
It could be the fuel damper. There's a recall on it look it up.
File Type: pdf
Old Feb 2, 2019 | 06:20 PM
Zmon's Avatar
Zmon
OP said he did it in the first post.
Not much to tell you besides take it back to the dealer and have them fix it considering it most likely happened due to the recall work. That's what I would do anyways.
Old Feb 2, 2019 | 06:38 PM
MikeFig82's Avatar
MikeFig82
Well as the OP is still trying to crank while leaking gas. The car might not make it back to the dealer.
OP be safe and tow the car to the dealership.
Old Feb 3, 2019 | 10:55 AM
aimer100's Avatar
aimer100
Thank you all for the suggestions. I'm going to try and find the leak and assess the damage. If it's more than an easy fix then I'll try the dealership.
Old Feb 3, 2019 | 03:25 PM
aimer100's Avatar
aimer100
Hello, after looking under the bonnet I found this. There is a gap between the two parts of metal where my pliers are pointed. The top has open screw holes or something? Did screws fly out???
Old Feb 3, 2019 | 03:32 PM
Nad1370's Avatar
Nad1370
Where the hell are your bolts that hold that down?
I think that is part of the dampener recall that was done.
Either you call the dealer who did the recall and have it towed to them or find some 6mm bolts to secure that down and drive to the dealer.
As long as its not leaking after.
I'd call the dealer.
Old Feb 3, 2019 | 03:42 PM
aimer100's Avatar
aimer100
Is this the most recent recall, or one from a long time ago? I bought this car used and only had the recent fuel related recall.
Old Feb 3, 2019 | 03:57 PM
Nad1370's Avatar
Nad1370
I dont know which recall they did on your vehicle.
You can look at your repair order on your receipt.
But that looks like your fuel pulsation dampener.
Missing 2 6mm bolts (i can see, there should be 3) that hold it down in place.
I think Mike posted the recall on his previous comment.
Looks like the recall was released June 26 2018
Old Feb 4, 2019 | 08:53 AM
Zmon's Avatar
Zmon
I don't believe they touch those bolts during the JLF (dampers)recall, at least according to the NHTSA repair document. https://static.nhtsa.gov/odi/rcl/201...8V432-3527.pdf It's also not touched during the old ELF recall as well (the fuel pressure sensor gasket recall). The only recall where it is actually touched and removed is the ALE recall (the valve spring one). If the OP had that done at the same time, or the previous owner did it, the dealer forgot to put those bolts back. I had the JLF recall done a few months ago and recently the fuel pressure gasket started to leak so the dealer redid that recall claiming "the increased pressure from the new dampers and a slightly loose sensor caused a bit of fuel to leak", so that may be the same case here with the OP and his missing bolts.
Old Oct 24, 2019 | 09:22 AM
Wanchani's Avatar
Wanchani
Default Bro i just had the same problem..
Originally Posted by aimer100
Hello Everyone,
Thanks
Yeah I took it in to get the fuel rail recall and I was just simply driving down two lane Street and my VSC went off I reset my ECM with the negative terminal on the battery and 2 two fuses and vsc keeps popping up... on hot days when I run my ac I would smell gas fumes blowing throw my cabin. Interesting enough on cold days it doesn't happen ...... anyone find anything yet
Codfish
Jul 15, 2018 11:52 PM
GaryJG
Jul 6, 2018 07:39 PM
Oro
May 19, 2017 04:08 PM
GS498
Apr 26, 2014 12:48 PM
2001blueA6
Canada
Dec 19, 2007 05:42 PM
