My midpipe leaks
Old Jan 31, 2019 | 09:46 PM
vincerulz's Avatar
vincerulz
Default My midpipe leaks
Hi guys my 2009 is250 awd had leaks on the midpipe theres 3 holes on it. I did some research and I know that no aftermarket company that make midpipe for AWD model. I’m not sure which is best way to go with. Get OEM or get aftermarket and custom fit it. please help me !! thank you !!
Old Jan 31, 2019 | 10:05 PM
flowrider's Avatar
flowrider
Veteran: Air Force
See this thread:
https://www.clublexus.com/forums/per...is250-awd.html
Lou
Old Feb 1, 2019 | 05:05 AM
moses0324's Avatar
moses0324
mid pipes were leaking on my car a couple years ago...went to local muffler shop they cut old section out, bent new tubes, welded...done.
$250 for both sides.
Old Feb 1, 2019 | 05:19 AM
Bichon's Avatar
Bichon
I agree with moses0324; a competent exhaust shop should be able to cut the corroded section out, then fabricate and weld in a replacement. Some people on this board have even had success by just welding over the holes, although that strikes me as a band-aid fix that will just buy a bit of time.
Going the OEM replacement route at the dealer is super-expensive -- over $2k -- due to the fact that it includes the secondary cats.
pearllex09
Performance
Aug 19, 2020 11:43 AM
DB14IS250
Performance
Sep 12, 2018 10:26 AM
AyRow89
Dec 11, 2016 05:40 AM
TJR
May 15, 2013 08:29 AM
Nicecar
Performance
Oct 5, 2011 05:38 PM
