2012 Swapping 18" to 17" help
Old Jan 13, 2019 | 04:49 PM
Knawty's Avatar
Knawty
Default 2012 Swapping 18" to 17" help
Im about to be driving a lot more then normal , So mi dropping back from Stock 2012 18"s staggered F-Spot set-up to 17" x 8 all the way around thinking 235/45r17 Michelin pilot sport a/s 3+ ( looking for the best Wet and Quite tire i can get )
Having a hard time finding wheels i like ( gunmetal 5 spoke on Ultra White F-Spot) , but what offset should i be looking for on all 4 wheels ??
The change is because i need to get a lot better life out of the tires and more comfort in the ride.
all helpful input is very much welcome !!
thx
Old Jan 14, 2019 | 02:54 AM
bbaugher47's Avatar
bbaugher47
Im not 100% sure if 17” wheels will clear the front brakes.
Old Jan 14, 2019 | 02:59 AM
Knawty's Avatar
Knawty
im sorry
im doing this on a IS 250 so 17" are stock on them , it not a 350
Old Jan 14, 2019 | 03:13 PM
bbaugher47's Avatar
bbaugher47
Have you thought about finding used oem wheels?
Old Jan 14, 2019 | 05:34 PM
Knawty's Avatar
Knawty
yes , i thought about just getting 2 more front wheels and put on the back
just dont know a good place to find any
Old Jan 14, 2019 | 05:47 PM
sktn77a's Avatar
sktn77a
I went from the stock 18" staggered setup to the 17" stock wheels with 235/45R17 tires.. Much more convenient (rotation) and more comfortable ride. You can find the stock 17s on craigslist or ebay pretty cheap or from your local wrecking yard but I can pretty much guarantee you'll have to get them refinished.
Old Jan 14, 2019 | 05:55 PM
Knawty's Avatar
Knawty
yes Sktn77a the ones i have found or chewed up pretty bad
what Offset did you go with ?? + 40 , thats what im looking at
Old Jan 16, 2019 | 03:48 PM
timmy0tool's Avatar
timmy0tool
factory wheel sizing with offset:
17 x 8 JJ, 45mm (both AWD/RWD)
18 x 8 JJ 45mm (both AWD/RWD)
18 x 8.5 JJ 50mm (RWD's rear)
Old Jan 17, 2019 | 03:40 PM
sktn77a's Avatar
sktn77a
Didn't look - they were stock Lexus IS250 wheels. No problems10 years later
cruzinZ
Jun 18, 2015 05:32 PM
nflguy
Mar 14, 2015 04:30 PM
KaiserSea1
Sep 1, 2011 02:50 AM
lonwa
Aug 29, 2008 08:10 PM
Cephus
Jun 6, 2008 02:00 PM
