- GTE wont start after engine build. No Spark, help please
- power steering resivior
- W58 EXPERTS? 2nd and 3rd syncro revisions
- My car clunks when I put it in drive?
- Is it realistic to NA-T with 178,XXX miles
- 12v Mod Alternative?
- RPMs disappear upon throttle
- Am I screwed?... :-(
- Misfire, bucking, jerking
- Door Stuck, need advice asap!!!!!!
- na-auto to tt jdm auto???
- Extending the O2 sensor wires, any1?
- Sc400 manual ttc adapter questions
- Nitrous on sc400
- 1993 sc300 108k acceleration sputter HELP
- 2jz-ge turbo header wont fit big turbo fix
- 2JZ-GE VVti cam question???
- Harness extension question
- Disconnect Kickdown-switch for Dyno?
- Anyone rebuild their W58?
- GTE single questions
- instrument lights won't shut off SC400 1992
- JZ Swap & Na to Turbo questions....
- Power steering leak at snap ring & o ring.
- TopSpeed Pro 1 Exhuast
- For the 98+ SC300 Owners Exhaust Help
- 2JZGE - Which pulley is it?
- Is this the power steering hose or could it be more?
- how much boost
- Braided oil pressure line resizing?...
- 1jzgte what harness do I have?
- Meangreen1's GT35R build.
- Swap Pix
- Supercharger
- W58 Swap
- engine problems
- yet another random missfire/sputtering thread sc400
- Window Motor Help Please!! (with pics)
- Fuel pump not doing anything
- no compression in number 7 cylinder intermittent
- airbag dash lite needs reset
- 2JZ-GE cam shaft work in 1JZ-GTE?
- 2jzge turbo manifold thats tapped for t3 and t4
- converting sc300 into sc400 w/ manual trans
- IMF SC400 headers GB for the holidays $399!
- Sc300 heater control valve leak!!
- Sc400 Acceleration Problem
- Want to boost my performance on my SC
- Low boost, low budget 1UZ single turbo setup
- Apexi Neo Afc install help...obd 1
- my ehxuast smell like burn? werid?
- 92 SC300 Wipers stop working HELPPPP!!!!
- my 92 sc questions
- quick question: will sc3 cats fit an sc4?
- Auto Tilt Steering Wheel Fix
- mystery problem
- New Here...have some questions
- chattering sound from transmission.
- Ebay intercooler IATs...Post if you know them.
- car will not stat in the cold but will when its over 40degrees SC400....
- 2jzge timing
- Question...Switched to Mobil1...
- single turbo ?'s
- need help, wont start
- w58 swap
- transmission swap (need info)
- Spark Plug Suggestions
- Where to get alternator, and which one? SC300, wierd problem...
- Weird W58 tranny 3rd gear experience
- Harness schematic
- Bpu 1JZ Breaking up Underboost...Help
- Anyone installed a Supra LSD with 3,76 final gear?
- How Can I Get Cheap LSD!!!!!
- car bogging during WOT?
- SC300 OEM Differential
- Heater Valve Repair
- 1JZ + WOT = burned rubber smell from engine compartment?
- flash codes
- PPE Header Group Buy
- new to the game. driveshaft help please
- car overheats at idle.. help!
- sc400 oil pump
- header exhaust system?
- Anyone Running A Griffin Radiator
- Megan Racing Axel Back????
- Car jerking when let off of gas at any speed
- Distributor Delete Pics w/ 7m-gte CPS / vvti Coilpacks
- Will 95-96 SC400 Alternator fit 98-00 SC400 vvti?
- 92 lexus sc400 bad cylinder
- E85 fuel setups chime in
- Easy solution or engine head removal?
- Need help with turbo
- Whinning sound from engine
- 98 SC400 Fuel pipe replace
- Sad morning.
- Supercharged 400 - installing Adaptronic!
- Question about stock ECU's
- R154 rebuild kits?
- Aftermarket Heads for 1UZFE?
- OEM or probe pistons for rebuild
- Mk4 1.5jz project
- Oil in spark plug valley again!
- How do I tell if I have a Blown HG/Cracked Head or Cracked Block??
- 1jz single low boost dyno results!!
- GE motor with v160
- Sc with 1fz-fe with 76mm turbo
- speedometer and odometer stopped working
- Weird butterfly valve / throttle valve click sound..??
- 92 sc400 rough idle at 400 rpm intermittent
- Quick 02 sensor question
- First Lexus Project
- 1jzgte twin turbo upgrade?
- SC400 Knock Sensor Voltage Range
- GTE trans on NA motor?
- Play with the ecu
- 1JZ Side feed Injectors Installation
- Drift Motion Power Steering Line - Question
- Question about NGK plug wires...
- Launching a stock sc300
- Water leak/rear carpet getting wet...
- Power Antenna works in reverse - free 6pack to whoever figures this one out!
- 1JZ, 2JZGE Accessories compatible??
- Turbo suggestion please.
- does the sc400 tranny only take 2 quarts?
- Another Sc400 starting problem.
- Anybody use Vibrant mufflers? Pics?
- Proper W58 for the sc400 Swap
- Injectors maintenance
- Still havent gotten her running
- Transmission died
- W58 SC 400 long term report
- HKS Exhaust
- 1jz to good to be true? yes
- thread for stock bottom end redline?
- When cold... Stuck Ignition, Starter, Solenoid? Or What??
- 1jzgte swap problem.
- restricted air intake-------any advice appreciated
- Tansmissions.....No this is not another W58 or R154 thread
- 2jz na-t intercooler size and choice?
- Rod that connects to door handle
- dr Tweak Harness and aristo ecu
- KAAZ LSD for SC400 questions
- Head Stud question
- Car randomly turns off. (EGR?)
- EGR valve
- Cold start rattle
- Vibration. Tranny or Engine mount?
- Sc400;The 1JZ Swap Adventure
- ct15b high flow upgrade
- Starter question?
- 1JZ breaking up in cold weather
- Masses of white smoke but not the headgasket?
- Fuel + Electrical problems
- 1j single setup question
- Whistling sound only on partial throttle.
- 1jz swap, dropping fuel guage needle?
- 2jzgte swap cruise control not setting
- does the 97 sc300 have traction control??
- Need help with buying an LSD.
- Blown head gasket fix estimate
- Lexus SC 400 Ignition Coils
- aristo transmission swap?
- Reverse plug part #
- Solved CEL Code 71 EGR by changing fuel filter
- Lets play a game. "Wheres this noise coming from?"
- 60 MPH @ 4,000 RPM's HELP!!!!!
- Steering wheel having sligtly delayed steering response?
- HKS Type S FMIC kit for Supra TT
- Scared I Messed Up My Ride
- supra tt pump lines.
- Some rambling, questions and need advice. Considering an EMS.
- OBD II ECU help
- radiator light comes on and off mid drive?
- need help sc400
- SC400 transmission problems.
- Occasional starter kickback
- boost guage line question 2jzgte
- Dreaded starter click - changed starter and I still get the starter click randomly
- newbie sc400
- Fault codes.
- 1jz bpu question
- Quick quick question please answer!
- na-t fuel injectors..who is running stock?
- Maf?
- can I get any info on the reliability of this website?
- Evaluate my service deal/labor costs
- '92 SC300 with high NOX --failed smog today
- For those with 1UZ Manual Swap
- catalytic converter delete
- mass air flow or tps?
- Am I Missing Something? (pic)
- JZA70 to SC300 wiring
- Garrett GT3071 on a bone stock 2jz?
- How Much for a 1JZ Setup?
- Trying to add a fuse (Help please) ...
- 2JZ + Tremec T56 ?????
- Exhaust manifold/ catalytic converters
- Oil for engine fan fluid in a 1993 s 400
- warm start, and dies while driving
- A few questions about white smoke, disappearing coolant and rpms
- turbo on na 2jz-ge
- 1992 Sc300 F/IC problem with MAF
- sc400 swapping rear end : gears 4.10 vs. LSD
- Swap wiring question?
- Downpipe question...
- Car is all the sudden started dumping oil. Please help
- Stalling in automatic sc400.
- Coolant block test pictures - head gasket
- Car makes loud whine in the morning
- Will these exhausts fit?
- Start up issue.
- Oil cooler location help!
- automatic starting in 3rd-4th gear?
- 10" Subwoofer install in stock location (PICS)
- hks hi power exhaust???
- My new fall/winter project
- Timing Belt
- gas line questions
- Cranking boost to just below fuel cut...safe?
- Fel Pro Gasket Paper?
- What kind of leak is this???
- Help with AEM FIC 6 1jzgte SC400
- sc400 performance...lacking
- New Battery for SC300
- fuel pump? your call
- Sequential is a go! Finally... Transition boost question for the twins lovers
- Phantom parasitic power draw (about to get rid of SC)
- SC400 turns over but wont start
- Starting issues
- Startup waterpump/timing belt replaced
- Proper hosing locations?
- Help identifying exhaust manifold. 1jz or 2jz?
- beaten by a 1uz
- Startup after waterpump replace
- Anyone know bolt size for bellhousing bolts?
- vvt-i 1uz w/ a w58 stick transmission?
- light weight pulleys
- sc400 5spd swap
- HELP!!!Required Bits and Pieces for M90/1UZFE
- driveshaft question
- NA-T engine bay pics, show'em
- 2JZGTE Strangest boost leak ever. Is this bad?
- Egr valve malfunction wont go away
- What clutch are you using?
- Busted radiator reservoir
- sc 400 1992 water pump
- I thought this looked fun for a weekend laugh...
- timing belt complication...
- need to find this part pls help
