2JZ-GE cam shaft work in 1JZ-GTE?
So I have a opportunity to pick up a 1JZ-GTE head for a pretty low price to make a 1.5J as I have a 2jz-gte, but for some reason the guy wants to keep the cam shafts cause he thinks there worth as much as head itself (unless they are, its the stock cam shafts).
Anyways just wondering can I use my current 2JZ-GE cam shaft in the 1JZ-GTE head?
huh interesting this thread was just made yesterday. I am also wondering if 2jz-ge cams will work in a 1jzgte head. just dropped off the head at the machine shop an hour ago. i have a GE head sitting around and was wanting to use the cams from it if i could because i bet they are bigger.
any more input on this?
the 2jz-ge cams are some what larger than 1jz cams aren't they?
meaning is it worth doing?
I was just thinking about the cams gear thing earlier today... I haven't looked at GE cams to see but yes stock GTE cams work with slight machining. USDM are better than JDM too. Can pick up stock USDM GTE cams over at SF for around $100.
Can't tell you the difference cause I'm doing this and going single before swapping. Read in a thread that a girl picked up 16 whp on this mod alone.
well my buddy with an vvti aristo swap in his is300 say that his cams have the distributor gear on it. toyota must not have bothered to design a new cam??
weird right. he just had his motor all apart a month ago so its for sure.
as far as my idea goes my other buddy has 2jzge cams laying around. and my 1jzgte head is at the machine shop right now. so i can get the cams for free and if it works then i want to do it for sure. i guess i'l be able to tell if they fit by seeing if they sit in there. that and th machine shop will be able to tell me. so ill let everyone know
as far as what dude is doing i have no idea. did you ruin your GE head?? i dont even know if the water passages are going to line up if u try putting a 1j head on a 2j block.
i ment 2jzGE block... i just remember reading that someone was trying to put a GE head on a 1j block and they had to cap a coolant jack to do it... if it was gonna get done. dont think he ever did it honestly.
lol. but no ur going to need vvti cams. sucks huh. dont even bother. just boost the **** out of it. get some water meth
and machine shop says that the stock 2jz-GE cams do in fact have more lift than the 1jz-gte stock cams by significant amount. they are saying that the distributor gear on the GE cams is going to have to be machined off. i talked to the main guy today and he says thats what one of his workers was saying. he said he is going to check for himself tomarrow and call me back.
i will let u guys know
machine shop is charging 150 to machine the gear off the cam and to machine the head so they fit right.
they are USDM 2jzge cams which have the same specs as the USDM 2jzgte cams according to this
http://www.turbosupras.com/pages/pag...ZA80/jza80.htm
besides that one degree on exhaust timing...
hopefully the duration is the same... should be right????
duration has got to be the same... so i'm doing it. callin the shop tomorrow morning and telling them to go through with the plan.
originally it was going to be 160 to just clean the head, plain it, check the valve clearances and put any in spec if needed.
now its an extra 150 to do the cams and re-due all the clearances.
so 310 total. i guess taking off that dizzy gear is some extra work so i dont think its a bad deal. im on a tight budget so any extra lift i can get im gonna take. plus it will be good to redue all the clearances anyways.
i'll take picks of the cam with the gear machined off before i put the motor back in. maybe i'll throw some pics of my blown 1j with no compression in cylinder one as well
