- Side by side pics of LS400 and TT calipers?
- Reliability and costs for 2JZGTE
- Built Auto Trans
- 92 SC 400 sputters
- New to the site
- about to buy my first sc300. just a few questions
- SC 400 Valve cover gasket?
- Codes 24 and 55... Stuck at work right now..
- PS, Speedo, Radio all went out. ABS light on. What just happened?
- Huge power loss Please help. PLEASE...
- guess who's car is still down...dies when in gear
- Vibration after 5spd swap
- Vacuum Hose sizes
- wierd vibration when driving. tranny or something else??
- AEM Map Sensor
- 98-2000 SC400 1UZ NA potential powers?
- Tuning and Injector Help 1JZ
- Where should I begin diagnosing loss of power?
- 1JZ wiring diagrams, schematics and info thread
- Trac and ABS relay delete
- 1992-1997 SC400 Primary Catalytic Converters
- 1jz VVTI swap info, a few questions.
- sc300 triple pump in-tank installation
- sc400 turning off when braking hard help.
- SC300 overheating again!
- 95 Sc400 tranny problems help please!!
- Hesitating sc400
- To helicoil or not to helicoil, that is the question.
- to Silicone valve cover gaskets, or not to silicone valve cover gaskets?
- sc300 exhaust
- Dashboard Problems
- Input needed; pics inside of my distributor cap
- Anybody with a 4.7 swap?
- 1JZ patch harness to 2JZ Aristo problem-CEL
- 5 Speed SC300 Won't Crank...Doesn't seem like clutch switch...HELP!
- my car finally starts and stays running...with a new problem
- T-IV or Dexron III for SC300
- Remove Cat or Resonator?
- **SC400 Crackling Under Acceleration & Stalling Issues**
- Bee-r Rev Limiter wiring help! (2jz-gte)
- Auto transmission?
- Cost to swap to a 2jz?
- IS300 LSD in a SC300?
- car shuts off by itself?
- Help with Clutch Fan install
- Catalytic Converters?
- Custom Exhaust system?
- Valve lifters and seafoam
- Transmission shift kit?
- Attempting injector replacement, need some advice..
- Engine Swap - '98 VVT-i going into '93 SC300 - I am going to rue the day...
- Using SC400 differential ring gear in Supra N/A diff?
- Planning on the doing the 2JZ-GTE Swap
- BOV block off for 1jzgte
- Power gains without Turbo?
- Very odd coolant leak
- IS300 oil filter on SC300?
- Transmission Question
- Trivial question regarding T-belt sticker
- JDM 2JGE weaker than USDM version?
- Eddie's 2jzgte swap
- Vibration from underneath when steering wheel is straight
- battery keeps draining
- SC400 noob with power steering questions...
- Ring Bushing Question
- Heater Control Valve help needed.
- Climate controls...no its not a fuse.
- sc400 to 2jzgte r154 swap help
- Couple Questions/ Problems...
- SC3 not entering diagnostic mode
- Removing Cat for Better sound??
- What else should I do while replacing head gasket?
- 93 SC 400 brake flush
- SC300 Coolant leak - Can't find source
- Timing Setting
- Waterpump leak after 6 months
- Supshortblock or rebuild?
- Dash wiring! Why?
- 97 to a 98 transmission swap
- Power steering out!!! Need new one.. But where with out breaking the bank?
- part numbers available: SC 2j shroud same as Gs 2j shroud?
- will there be problems?
- Need a battery
- Battery Issues Please Help
- Does the 97 +up SC 300's come wit LSD?
- getting rid of your fluid fan {sc400}
- 1jzgte question
- Sc300 auto shifter wont go into park
- Continuous battery/alternator issues.
- Lean surge at part throttle
- Invest in w58 and pray? or go r154 / v160
- Type IV ATF fluid- How much $
- Engine problems
- sc400 battery problem help??
- End of swap rev hunting issues
- Has anyone had an SC300 timing belt fail?
- Turnkey auto to manual swap WANTED, anyone qualified and available?
- 95 Lexus Sc300 Hp?
- GTE Swap vs NA-T for 600+whp
- Power Steering Pump? (video)
- I Need Help!
- Shift hesitation sc400 tranny
- Anyone used KS racing for 1uz w58 swap
- Clutch wont engage fully. Need Help!
- IAC / ISC price -- are you kidding me?!
- r-154 chance should i take it?
- precision 61mm at 8 psi...wastegate?
- 98 sc300 5 speed swap speedo
- 2jzge into a sc400 Questions
- Wrong Gas
- wastegate too loud
- Tranny Pan FIPG...How do I get the ****** thing off?
- Which aluminum intake pipe + filter for 2JZGTE with stock twins?
- Car still won't start. need help ASAP
- Gearing question. (with lsd)
- Leaking Coolant around the drain plug
- Transmission Fluid Black
- Showing Love and TopSpeed Exhaust Quesitons
- sc400 - question about multilayer steel gasket for waterpump
- Integration Relay and starting issue - Need Help!
- Sc300 1jz vvti project help needed!!!!
- weird wheel set up??
- My SC300
- 2jzgte-vvti harness ?
- Supra Exhaust Fitment... I searched
- Battery / alternator issue please help!
- R154 question
- Turbo and smog
- What else to remove while the engine is out?
- Cat converter and straight pipes
- Vibration when take off+quick pull (VID inside)
- post engine swap high idle and other issues
- Skew's SC400 GTE Build
- Sc400 help needed...car creeps to speed and cats are popping
- 92 sc400 ecu
- Please help! Changed slave cyl. black fluid & no pressure
- Trying to revive a 92' SC400, a few questions...
- Help with front main / oil pump seal
- 1200cc RC injectors question
- R154 Tranny Swap...
- Help me pin point this weird sound from my engine??!
- "Rough Idle then just die need help"
- Battery dies intermittently
- sc400 i need your HELP PLEASE LOL
- 2JZ-GTE SC300 slow acceleration in 1st gear
- check engine light question
- 92 SC400 is DEAD - Vid Inside
- Idle issue when warm
- 1uz overhaul before questions
- Code 13 and a Rough Idle
- How to wire 1JZ Batch fuel injection to Sequential fuel injection?
- 94 GS300 ecu in an 93 SC300
- Jdm 2jzgte alternator plug question.
- TT head gasket on NA?
- Is cold air intake really worth it?
- spark plug advice plz!!!
- UEGO and Vafc 2 install questions?
- help!!!!!!!!
- Blackstone labs oil analysis report
- Ruh-Roh........ engine noise
- Replacing drivers side key cylinder
- 93 sc300 injector size?
- Fuel pump or worse?
- help with aligning alternator pulley
- assessment from mechanic
- need help with my second 1jz swap
- Check engine light
- Manual Transmission Fluid Recommendations???
- Need some help sc300 94 2jzge
- Dtc 25, 26, 41
- bad battery cables?
- Changing battery cable harness on 92 SC400
- Overdrive & Other Issues
- Where can I find Axle-Back Piping?
- weird overheating issues
- DYI: Change your alternator W/ pics
- Power steering pump going bad??
- Ran up a curb...
- serpentine belt squeal
- Brake light comes on in hard left turns
- How "loud" is loud? 2012 Porsche 911 exhaust note compared to SC catbacks
- Is my fuel pump going out??
- 92 sc400 shaking at low RPMS
- Help!
- Automatic Transmission problem
- cigarette lighter not working and the RPM meter sick
- AEM V2 on Automatic's how do you like it?
- Rx7 injectors on 1jzgte question????
- 1jz question
- Converting to 5SPD - Question
- Whistling sound
- vvti wiring???
- 92 Lexus SC400 starting then shutting off
- uggh 92 sc400 wont turn over
- HELP! sc400 won't start
- one last time..brake light issues n shifter
- How much did you pay for your 1jz swap when it was all finished and running?
- mk3 supra halfshaft???
- Need expertise help. SC400 Overheating!
- P1349??
- SC300 spark plug (what are you running)
- LS1 swap first start up and idle videos
- Leaking coolant out of my EGR
- How to route heater/coolant hoses with a 2JZGTE swap?
- Quick Cam/Crank Timing Question After T-Belt Job on SC300
- has anyone put cams on 1uz?
- Sc400 jerks when gasing hard
- Specific situation.. Auto ECU to Manual ECU?
- 2jz bellhousing bolt sizes. help please
- New Sc 300 owner needs advice
- automatic motor mount
- rear housing
- 2jzgte wire harness and ECU in a 1.5JZ?
- More power in the lower gears
- 1997 sc300 Aem fic wiring dagram
- Rebuilding SC300 accessory belt tensioner
- Fluidyne Aluminum Radiator for Lexus SC300
- AN / JIC fittings on an Aluminum Radiator
- SC3 oil leak
- Best Battery
- Replace Timing Belt when getting my Starter done?
- 1JZGTE VVTi
- injector removal help
- Help with 1uz Flywheel...
- SC300 tensioner bearing P/N's
- 2jzge position sensor??
- Loud Alarm inside car
- SC400 2jzgte auto swap to a SC300 questions
- 1993 SC400 Heater Stopped Working
- sc300 na-t tuning issues
- 2JZGE Jumped Timing
- No spark no crank position sensor???
- is the sc400 radiator support the same as the sc300?
- Code 31, possible bad ground?
- engine wiring help
- am i crazy, or do i need another starter??
- 1jz swap- Where does this plug go?
- power steering assist? does it take some getting used to?
- ? On the wiring on a vvti 2jzgte
- Cam/Crank sensors
- car has no spark and wont start. help
- looking for LSD for auto gte swap
- IPT Valve Body upgade SC400
- IS300 5spd tranny
- Weird bucking issue
- Teaser pics of superchargers m112/M122 for the 1U-FE enjoy =P::::
- engine shaking after cleaning engine bay
- Electronic Exhaust Cut-Outs Pros and Cons
- lexus sc 400 (check engine )
