1997 sc300 Aem fic wiring dagram
There are a lot of wiring diagrams on AEMpower.com
This is basically wired up like a SAFC but with 2 exceptions:
-Timing. (You need to wire your igniter through the FIC, back into the harness, to the coils. This is how the FIC retards the timing under boost.)
-IAT wiring. Hook up an Intake Air Temp sensor.
Other then that it's like any other tuning software. 22x17 on the FIC IIRC.
It's pretty easy, and miles better then a SAFC.
Thanks bro, I guess I'm looking for is the ecu diagram for the 1997 obd2 Sc300 since I found a pdf file for the Fic already.
Has anyone tried out on 1997 obd2 sc300 with just the stock ecu, injectors,v8 maf and turbo kit 8psi?
does anyone have a 1997 sc300 obd2 ecu wiring diagram online so i can wire up my aem FIC? i found a wiring diagram for 2002 is300 with aem fic, will it be the same since its obd2?
Blk97SC300
SC- 1st Gen (1992-2000)
04-21-07 12:21 PM
