Sc300 auto shifter wont go into park
Old Nov 28, 2011 | 01:11 PM
Golden95SC's Avatar
Golden95SC
Unhappy Sc300 auto shifter wont go into park
Well guys im just starting to put the car back together and now the problem is that it dosnt wana go into park. It goes into everyother gear but park. When u try to go to park it feels like its being blocked and it wont go in.
Heres a pic
And in this one it shows as far as it wiling to go. U can see that it dosnt make it.
Anyone know what this could posibly be?
Old Nov 28, 2011 | 03:48 PM
1980's Avatar
1980
Try and adjust the linkage under the car. Happened to me. The bolt came loose and it would slide in the slot.Its an easy fix.
Old Nov 29, 2011 | 01:49 PM
Golden95SC's Avatar
Golden95SC
Oh ok how can I check that? Wats needed to do for this procesd? Also today I pushed it into the park position but now its stuck in park and wont move
Old Nov 29, 2011 | 04:34 PM
1980's Avatar
1980
Jack up the car, look under it. You should see the transmission and the shift linkage.
If I remember right I think there is a rubber boot on the bottom of the shifter that covers the shifter and linkage. The bottom of the shifter will have a small 10mm nut and bolt sittin in a slot at the end of the linkage.
Loosen it up a bit then shift the shifter into park. A friend helps here.
When its in park shift the transmissin into park using the linkage. I think it goes back afew clicks.
Now the bolt and linkage should be lined up. Tighten the bolt. Then check to make sure all gears work.
That should get u in the right place. Might need to move it afew times to get it just right. Hope this helps you. good luck
Old Jan 5, 2012 | 08:09 PM
Blk96sc3's Avatar
Blk96sc3
try goin from 1st to park a few times with key turned in ignition...worked for me
micsil2008
RX - 1st Gen (1999-2003)
Mar 28, 2017 08:24 AM
mfb496
Sep 3, 2012 05:11 AM
986ci's
Feb 29, 2012 06:53 AM
romeo291
Nov 10, 2008 12:32 PM
veritek
Feb 23, 2006 01:55 PM
