More power in the lower gears
Is there something I can do to get more power in the lower RPM's? It seems that the SC4 is a little slow on the start...Now I am no racer so maybe I'm just not driving it right..lol It seems great on speed once I've gone through all the gears...man wishing they came in a manual...
there is a thread that discuss unplugging a sensor thats located on the transmission. i tried this and there is a noticalbe difference when moving off. The sensor make to tranny slip when shifting so you get a smoother ride,so with it disconnected you are getting all the power. i will search and try to find the thread.
Keep in mind the 1UZ doesn't produce peak torque until 4400rpm, and I find the transmission upshifts too quickly to make use of this, keeping the car feeling sluggish from 2000-3000rpm a lot of the time unless you really get on it.
Here's the aforementioned thread:
https://www.clublexus.com/forums/per...-its-free.html
I find myself using O/D off and using '2' a lot of the time around town because the transmission doesn't seem eager enough to downshift sometimes. I also have adjusted my TPS and now the car holds first gear for a bit longer, which definitely makes it feel less sluggish from a standstill. There is a thread on that too somewhere but I can't dig it up at the moment.
source: lextreme.com
you want more rpm without getting into it? shift manually at 4000. pretty useless, though, as when I'm just putting around, the shifting and power are just fine. When I need to get into it is when I am dissatisfied
I keep hearing about all these 1uz's with no power... I don't have that, and it makes me wonder what's WRONG with my car...
