- Airbag or dash working itself loose, a crickety squeak.
- Does this sound "normal"?
- Scan and Coding Program
- Mixing Tyres & Widths
- Buzzing sound on passenger side
- Weather stripping for RX330 grille
- SS brake hoses do make a difference....
- Transmission fluid replacement intervals
- Caliper slide pin issue
- Steering column quick “hack”
- Building a center console arm rest
- 2004 - Power Steering Hose Replacement
- 2006 RX: Rear Middle Seat
- 2004 RX330 air mixer servo location?
- P0171 & P0174 codes with P0300 on 2006 RX400h
- Code p0012 and p0015
- Whirring noise 2005 rx300
- Radio fuse costantly burning out
- Back Seat Removal
- Clicking sound from driver’s side footwell
- Climate Control system is not working after upgrade with aftermarket android stereo
- Getting Alpine deck to work in 04 RX330
- Air suspension conversoin
- Service manual
- HVB upgrade
- 07 RX350 Clock Issue
- 15 2grfe to a 09 rx350 swap
- swapping 05 330 telescoping wheel to 06 400h
- Battery tender not working with 2005 RX330
- What type of bolt for ac condenser lines?
- Help! Cant get in to the car! RX300 (2004)
- RX33 won't start
- Lexus RX hidden features
- Camshaft Position Sensor Codes P0365 & P0368
- Adjusting low beam on 09 rx350
- Replaced old liftgate supports on my '08 rx 350 and now it won’t auto close
- Driveshaft vibration?
- Black Grit in Oil Filter Housing
- Interior LED spruke up!
- 250 milliampere battery draw: normal or parasitic draw?
- Ugh, I hope not...my car is a WEEBLE!!!
- Locking wheelnuts
- Rx350 motor swap
- Seafoam Spray Fixed My Engine- It's a good day!
- Towing Without Towing Package
- Rx330 fwd 2004 77kmiles strange dragging
- New Engine in a 2008 RX VS Cam Gear
- Coolant loss
- Need lelp with maintenance p/n
- Throwback: RX400h at Nurburgring (2005)
- Ground wire
- 2008 Rx400h Rims sizing upgrade
- 07 RX350 AWD AC Relay Location?
- polishing headlights
- Battery indicator disappeared??
- Rx350 NEEDS help Pls.
- Rx350 shocks & struts ..w/air or No air
- Wheel refurbishing
- C1241 c1391 codes ABS VSC warning lights
- Wing Mirror
- Catalytic Converter - 2005 RX 330
- Fog and headlight lights not showing in console
- Does your rx350 use oil?
- Leak from the rear
- Timing belt broke - how to check for valve damage?
- Rx450h steering wheel on Rx400h
- Parasitic draw from amplifier draining the battery
- rx350...does it have oil pan filter?
- 2007 RX350 back hatch won't open with automatic button
- Rx400h misfire
- P0171 and P0174 Lean Codes HELP needed
- thud/clunk from rear end of RX?
- Help me choose an RX
- c1931 code - pressure leak in ABS
- Crankshaft & Camshaft Correlation Waveform 3MZFE CKP/CMP
- Thinking of buying 2009 RX
- Clogged rear windscreen washer
- Small light above the 9005 light in a lexus rx330
- Can bus ready?
- Knock Sensor Replacement
- Radiator done sprung a leak
- Replacing Nav Display
- 2004 RX330 coolant leak, from radiator or reservoir?
- 2009 RX350 draining battery
- 05 RX 330 Rack and pinion steering u-joint.
- How Rare is a 2004 RX330 w/ Performance Package
- "stuck" with my 07 350 for now
- Easiest way to reinstall stereo angle bracket screws
- School me on the RX350 Reliability and High Miles (200k+)
- How hard is timing belt on 2004 Rx330?
- Oil Leak? Not too sure & need help
- Volume & Audio controls not working. No nav
- Knocking noise behind instrument panel ??
- RX400h tyres for RX450H
- painting - wrong color
- Disconnect DRL lighting
- Worth repairing?
- High beam led
- Used RX good purchase?
- Drain holes from aun roof
- 2000 lexus rx300 interchangeable parts
- Upper Oil Pan replacement
- No headlight reminder buzz?
- 2006 RX400h misfire at start
- 2006 RX 400h wont stay running
- 08 lexus rx350 no power windows, no wipers, no radio or hvac controls
- Upgrading Headlight Housing Assemblies
- Nav Disc for 400H 2006
- 2005 RX330 Differential Fluid Replacement
- Replace Transmission Fluid?
- Looking for 12v 'high' on 'ready'
- Central door lock no't qork on RX400h
- Can I Cut Bolt Rather than Remove Gas Tank
- Fuel consumption display
- Hip, hip hooray
- multiple codes point to oxygen sensor - RX330 2005
- Power steering leak / recommended fluid for 2007 RX350
- Switches on left side won't illuminate
- Gone but not forgotten
- Keeper Engine Strut Mount? RX350
- 09 RX350, Very low on Power Steering Fluid - Options?
- HID housing moisture
- For your eyes only
- lousy mileage
- RX vs GX
- Audio Off Message on Screen after iSimple install
- 2004 RX330 - only get hot air when temp is on high
- Best struts?
- Replacing rack and pinion
- 07 RX 400h fuse box locations?
- P0705 code help 08’ rx350
- Odd Squeak Coming From Rear Over Bumps
- Speedometer not working
- Lexus RX 400h P0A78 Not working Hybrid system & the rear motor is not working.
- Brake squeak - what do I lubricate and with what?
- 2007 RX350 Strut replacement
- Are 2007 Lexus RX 350 and 2007 Nissan Murano 3.5l engines compatible ?
- Converting Center Console Tray Charge Port to USB
- Can ECU drain battery?!
- high mileage motor oil
- Can I swap my 100 amp alternator and put a 130amp alternator in my 2004 rx330
- O2 Sensor Clip Part Number
- RX on 24”
- RX330 Rear Leak (differential?)
- Catalytic converter
- Keep climate screen on always?
- difficulty reading oil level..anyone else??
- 2005 RX330 CANNOT get rear windows to operate after battery died
- What is this beeping?
- Thermostat DIY with pics
- drls
- Which Power Steering Pump is best for $150-$200??
- Coolant Leak RX330
- Valve cover gasket Oil Leak
- Pleasantly pleased w/ the gen2 rx
- Need a clip, but don't know part number -help!
- Best way to upgrade my audio system
- Coolant leakage, how serious it's?
- Car starts without brake??
- U joint
- Navigation System night mode
- power steering fluid
- 2004 RX330 Often Hestiates When Shifting
- 04 rx330 air suspensijb
- Wipers not working properly
- Rx330 transmission pan
- pcv valve(s)? symptoms? and how many of them?
- help me sort moms 2007 rx350 - all PM type work - what to do?
- Installed roof rack delete kit
- New Lexus Owner--Questions already :)
- Milwaukee M12 Ratchet 1/4" Drive for DIY Repairs- Is It A Winner???
- Rx400h rain water leak storm ciara from map light
- Most common Causes of coolant leaks on 2007 rx350
- Power steering problem
- School me on RX-350 rear differentials ??
- 2005 lexus rx330 timing belt replacement
- Vibration when in idle in Drive
- Tail light relay location
- ABS VSC BRAKE Lights Help!
- Trans fluid, What are you guys using?
- Which line is which on cooler?
- Upgrades/Modifications/Updates
- RX330 Climate Control Icons when off
- AWD W/ Air Suspension replacement
- Rear rattle driving me crazy!
- How to replace Rack and Pinion Boot
- Notes for Replacing Rear Struts and Mounts on 2009 RX350
- RX400H Yaw Sensor
- Rx400h passenger door removal
- Wiring help! Dead head unit/nav screen?
- How to get service bulletins
- 2nd radiator???
- Anyone using RAYBESTOS Specialty rotors?
- Belt squealing 04
- Tilt/telescope control
- airbag on, passenger airbag always off, then check main battery
- RX330 ECM Replace & Swap Out - Advice and Tips Appreciated
- How could a mouse get inside?
- Keyless Entry
- Car parts
- How’s the standard 9 speaker audio system? Any good bass?
- Alternater replaced, now no heat !
- which gas do you use? also..is Ethanol bad?
- Interior Lights not working
- Cargo cover replacement clip
- Desperate for help!!!!!! ABS reset
- Help I don’t know how to change low beam bulbs
- 09 RX350, SRS Light On, ODBII Code B1100
- Red Battery Light is On!
- 2008 rx usb/aux/bluetooth audio options?
- Weird issues
- Random stalling when shifting gears
- 04 RX330 DIY key programming
- Fuel pump longevity
- abs pump broken
- Constant Low Coolant Gauge
- Liftgate won't open 05 RX330
- 08' RX350 - Front Windshield Washer Nozzle Replacement Part
- Parking Brake Stuck
- Transmission oil changed by wrong type
- 2008 RX350 headlight switch broken/detached
- School me on 04 rx330 air suspension
- Fog lights work inconsistently in my '08
- RX400h - Bluetooth capability
- Wiper failure
- Dealership won't disclose service
- Trans cooler options
- over heat at idle, no heat in cabin
- RX Transmission Assembly Service Diagram
- My new 2nd Gen RX400H and some questions
- RX330 Injector Failure Replaced With Flow Matched Upgrade- Smooth
- Do newer map DVD systems work in older cars?
- 17 vs 18 inch wheel feel
- RX330 Power Steering Upgrade Mod and Repair
- Missing vacuum hose?
- New to the club! - RX330 2006 - Dashcam placement?
- Duplicate Master key fob wont open trunk 2007 lexus RX 350
- Replace driver side blend door actuator (Right hand drive model)
- getting to transfercase top plug, how? help..
- Help me choose which Lexus RX350
- What do you think of this RX330?
- 2008 RX400h Low Beams
- timing belt issues.
- Initial diagnostic: all 6 cylinder misfires. Help!
- transmission pan (10mm) bolt part#?
- 2007 RX350 Center Console Lights Not Working
- Brake Accumulator part number?
- What is this noise?
- Help my car is shaking the crap out of me
- Life of your spare tire is limited
