Wiper failure
Old Jan 15, 2020 | 12:06 AM
Planner's Avatar
Planner
10th Gear
Default Wiper failure
Hi thereDriving along my wipers just stopped, in the up position.
Managed to push then down almost to the down position, but I can see them kinda try to move a little now and again.
It's not the fuses, I checked (Incidentally, that's the worst placement of fuses of any car I've ever had).
Is more likely a relay or motor issue?
Old Jan 16, 2020 | 06:06 AM
Margate330's Avatar
Margate330
I see this is your first post so-
Welcome to club lexus--!
Can I ask what is your year/model and mileage and if you had any other symptoms before your wipers suddenly quit?
Old Jan 16, 2020 | 06:21 AM
Nad1370's Avatar
Nad1370
Your symptoms show a wiper motor is going bad.
The fact that your wiper is moving some means there is power/ground from the switch.
But your motor is just shot.
Try turning your wiper switch to the ON posistion.
Then “help” swing the wiper and see what it does.
Old Jan 16, 2020 | 06:57 AM
Planner's Avatar
Planner
10th Gear
Just a quick update to everyone here as a thanks to those who replied.
Between the rain, I found a nearby scrap yard that was breaking a 400h. I tried a relay, and it wasn't the relay.
So when I took off the panel to try a new motor instead, it turns out that a cable (I think the one that goes to the front windscreen heater?) had broken off and got completely tangled in the mechanism.
As soon as I untangled the wires the motor started working properly again.
I'm not sure what damage being jammed all of that time did, and as it was already out, I replaced it anyway (£30).
Old Jan 17, 2020 | 07:02 AM
Margate330's Avatar
Margate330
...Just a quick update to everyone here as a thanks to those who replied. ... I replaced it anyway (£30).
Awesome job! Thank you for sharing your fix.
I was thinking same thing that your motor was a junked but it's good you probably repaced it anyway cuz who knows how much life you
took from it with it bound up in a harness.
Old Jan 17, 2020 | 07:12 AM
Planner's Avatar
Planner
10th Gear
No problem. And just to say that replacing the relay and the wiper motor/linkages are both very very easy jobs in a 400h.
I managed to do it with a phillips screwdriver and a spanner in less than 30 minutes.
it was actually more hassle checking the fuses than it was replacing the entire wiper motor, which says a lot for the placement of those damn fuses.
BrazzleAZ
Mar 13, 2025 10:27 PM
DevoPROCw
GS - 1st Gen (1993-1997)
Mar 3, 2018 12:08 PM
bucknasty4
Mar 23, 2017 11:24 AM
olecarman
Nov 12, 2015 10:42 PM
olecarman
Mar 17, 2014 03:16 AM
