P0705 code help 08’ rx350
Old Mar 3, 2020 | 11:37 AM
75damien's Avatar
75damien
Default P0705 code help 08’ rx350
Anyone run into this problem? Prior owner had a remote start installed but don’t know from how long ago. Looking at the fob maybe 2009 era compustar 1 way remote.
Weird other lifts on also p0705 transmission range sensor A circuit
Old Mar 3, 2020 | 02:30 PM
Nad1370's Avatar
Nad1370
Check the PRNDL switch on the transmission.
Could be corrossion in there.
Old Mar 3, 2020 | 04:14 PM
Margate330's Avatar
Margate330
Ok giving it a try.
Does the gears match in the intrument panel cluster when shfting thru gears? (signal to cluster gear position info is received from gateway ecu- no direct path from cluster info to shift linkage so linkage adjustments and connector corrosion, etc to switches can matter).
>> Here is the part of the code that suggest it thinks it is in more than one gear position simultaneously- possibly located in pic above.
P0705 "...The park/neutral position switch sends a signal to the ECM according to the shift position (P, R, N or D 3*1, or 2*1). The ECM determines that there is a problem with the switch or related parts if in receives more than 1 position signal simultaneously. The ECM will turn on the MIL and store the DTC."
If problem still persists just thinking maybe can something to do with aftermarket remote failure with custom wiring into Neutral Switch or something who knows but need more info/details.
Old Mar 4, 2020 | 12:02 PM
75damien's Avatar
75damien
Ok giving it a try.
exactly my thoughts. I will need to disassemble car remote starter then go from there.
the light does not illuminate once put into D or if swiped left to 4 position. All other gear points illuminate.... vehicle has always started , never a no start. I thank you and other person for feedback.
mom limited time info in Alaska lol.
LDlady
Nov 14, 2018 11:22 AM
Dally18
RX - 4th Gen (2016-2022)
Nov 22, 2017 05:50 PM
doitra
IS - 1st Gen (2001-2005)
May 11, 2011 01:53 PM
Moogy
Apr 29, 2008 09:16 AM
G02
Jan 31, 2008 02:18 PM
