Rx330 transmission pan
Old Feb 11, 2020 | 05:34 AM
acarapella's Avatar
acarapella
Default Rx330 transmission pan
Hey all,
This tranny pan has 1/3 or more of its bolts above the frame rail. Looking at it, I’m 50/50 on weather or not it can be done without raising the trans or lowering the frame. Has anyone done it? And if so, can they offer some comforting words haha
thanks
drew
Old Feb 11, 2020 | 06:32 AM
Felix's Avatar
Felix
Need to use a offset ratcheting box end wrench.
Old Feb 11, 2020 | 11:21 AM
acarapella's Avatar
acarapella
Cool so the bolts aren’t so long they hit the frame before clearing the threads
Old Feb 11, 2020 | 11:42 AM
Margate330's Avatar
Margate330
+ 1 on this.
Once the trans is jacked up just a little bit the access to those bolts over the frame are easiest with an offset ratcheting wrench to clear the lip on the pan.
It can be done without the offset but harder of course.
And a 1/4" drive with swivel will make fast work of a few other bolts that are near the frame.
PS- If you loosen the motor mounts all around (qty 4 total) the trans jacks up a little higher/easier but makes more work too so I only jack it a little what I need loosening the front center mount and trans mount.
Old Feb 11, 2020 | 02:47 PM
acarapella's Avatar
acarapella
thanks a lot guys!
Cap425
GX - 1st Gen (2003-2009)
Jul 6, 2018 05:29 PM
dguaraldi
May 13, 2012 07:44 AM
GFC350
Nov 29, 2007 10:35 AM
$C300
Maintenance
Jan 16, 2007 05:04 PM
Styx
Performance
Jul 9, 2004 12:58 AM
