Knock Sensor Replacement
Old Apr 15, 2020 | 09:00 PM
Jrx330's Avatar
Jrx330
Default Knock Sensor Replacement
Got the code P0328 today in the morning... looks like I need to replace bank 1 sensor. Can anyone give me tips or instructions and location on this sensor. Would be much appreciated!
Old Apr 17, 2020 | 08:08 PM
DennisMik's Avatar
DennisMik
On the 3.5L engine, the 2 knock sensors are located under the intake manifold. See item K2 in the locator pic below. I don't know how similar the 3.3L engine is.
If the engine is not running properly, the knock sensor is merely doing its job of reporting that and does not need to be replaced. If you have other code indicating engine problems, fix the problems indicated by those codes and the knock sensor code P0328 will most likely go away.
Since the knock sensors are under the intake manifold, replacing them will be a somewhat similar task to replacing the spark plugs, which is a challenging job.
Old Apr 17, 2020 | 08:28 PM
Jrx330's Avatar
Jrx330
Default Well no other codes had popped up so.. what now?
thanks for the reply! Very helpful, but that morning i scanned it and it was only the P0328 code that was there. So do you suggest I run it to see if others come up? Let me know what you think. Thanks! Just don’t want to ruin this reliable beast! Never had issues until now. Nearing 100K miles so I guess I’m not surprised something comes up now.
Old Apr 17, 2020 | 08:56 PM
DennisMik's Avatar
DennisMik
If you don't have any other codes, then it looks like the knock sensor is bad. Does the engine start smoothly or does it struggle for a second or 2? Again, if the engine is truly running ok, then the knock sensor is the problem.
Reset the code and drive the car for a day or two and see if the code comes back.
I'm not sure about toyotas, but if you have a knock sensor code, the ECU may retard the engine timing, which will reduce the engine's performance to reduce/prevent any possible harm. Retarding the timing is not in itself harmful.
Old Apr 17, 2020 | 10:03 PM
Jrx330's Avatar
Jrx330
Default Runs good and starts up fine
Yeah engine starts just fine no problem. I guess I’ll have to replace that sensor. I’ll reset and go on from there and see if it comes back with just that code or others along with it and I’ll see. Thanks for your help!
Old Apr 18, 2020 | 03:13 PM
doverrx330's Avatar
doverrx330
Hi,
I had my mechanic replace my knock sensor last year. He is VERY thorough and has been servicing my vehicle for years. The following is what he replaced since he had the engine apart but you don't have to:
2 Knock sensors
Knock Sensor Electrical Connector
Valve Cover Gasket with spark plug tub seals
Engine Variable Valve Timing Solenoid
Intake Plenum Gasket
Spark Plugs
This is alot but since the engine was open and all these part are connected and help with the functioning of the Knock Senor, it saved me money. My RX has 176000 mile on it so he also flushed the radiator. Like I stated earlier, you don't necessarily need to replace all that but he did.
Old Apr 21, 2020 | 11:07 AM
haku's Avatar
haku
just be careful where you buy your knock sensor. there are a lot on ebay for ridiculously cheap but they're fakes!
thread here: https://www.clublexus.com/forums/es-...k-sensors.html
i read knock sensors do not usually go 'bad' but more likely the wiring harness as it can get brittle over time (get denso or equivalent as the wires are suppose to be shielded to reduce interference)
marty99
14
Dec 5, 2023 05:01 PM
Dan040286
Aug 17, 2019 03:32 PM
Stemmer
RX - 1st Gen (1999-2003)
Feb 7, 2015 03:16 PM
SICK350
Mar 11, 2014 05:20 PM
Crown
Mar 15, 2012 03:25 PM
