View Full Version : Maintenance
- Strut Mounts, Boots, Insulators
- Anyone Used the Oil Extractor?
- LX 470 Timing belt failure???
- help... pass side rear window
- Floor jack recco's?
- Oil change PROBLE"M........ HELP !?!?!?!!?!
- Help with intake removal to change plugs and distributor
- How much is it to get the car inspected at the local Lexus Dealership?
- Can anybody get me a service report for this jt6ht00w4y0109028
- Differential fluid plug removal
- Oil Filter to use?
- Oxygen Sensors '95 LS
- Need a toyota part number for an air filter.....
- Code 29 on a 92 sc400
- Transmission Flush/Change?
- Fuse Box Question
- Pwr antenna is broken
- Will 60K svc at non Dealer void /CPO Warranty
- GS400 overheating solved
- Battery light came on.....
- How Much For A Good Paint Job ?
- MINIMUM Lexus Maintenance Schedule
- best plugs for the gs3
- Oil Changes?
- maintenance
- Noisy AC Clutch
- Antenna nut removal?
- Where is the Fuel Filter?
- lx470 sensors
- rolled 100000
- Best Battery???
- Battery Replacement...
- Questions for 90 LS
- Changed Tranny Fluid in my driveway
- Lexus Maintenance
- Idle Sensor (part of throttle body?)
- EBC Pads: Brake Dust!
- Naive First Time Lexus Owner
- Is there a good mail order Lexus parts store
- The engine stalls after the battery check up!? Experts, please help!
- GX470 Thug
- Window regulator Broke. Help!
- Lexus LX470 suspension
- Body Shop info around Louisville,KY area
- Why does my car stall ? (video of tachometer)
- 90K service experiences
- Anyone here under 21 that gets Lexus loaners?
- Where is my fuel filter?
- which "repair manual" cd is best?
- Engine decarbonization?
- Rear Right Rattle!!! 96 ES! Help!
- passenger door handle wont open door
- 1990 Es250
- AC Cabin Filter not found in 98 ES300
- Corrosion here. Do I need to take action?
- my battery popped today, again
- 1990 250
- 3rd brake lightbulb - LS
- 97 ES300 Rear brake install problems
- Brake life
- Check Engine Light
- I might be screwed
- Power steering pump or alternator problem
- coolant level changing
- Help, SC arthritis!
- Car won't start...suggestions?
- Any one know how to remove AC Evapoarator?
- FuelSaverPro Increase gas mileage by 27%+
- Mobil 1 Best Oil Filter?
- service at Toyota shops
- Passenger Window Not Working (not regulator)
- Has ANYONE had PROBLEMS with 1sourceautowarranty.com ??
- a/c pressure norms
- How to recharge AC?
- Help Me Change My Battery
- timing belt change 98GS400, prices?
- window trim 2002ES
- Brake vibration-feedback through steering
- Brakes service at Toyota?
- evaporator core
- AC system recharge on Ls400?
- Help! Info on parking brake adjustment
- Where is the ac filter?
- Passenger door handle wont work
- synthetic oil or dealer oil
- Problems Starting
- Where do you have your SERVICE WORK done?
- Help! My Car needs a Tune up!
- '00 GS300 clicking..no crank??
- Brake light warning on dash!
- 95 and up LS400 owners!!!
- Things used to clean the Airflow Meter.
- a/c flush
- 1996 LS400 Oxygen Sensor
- *over filled oil, oops, is it a problem?
- Ls finally had it's stall
- 1000 threads sweet!
- Caps and Rotors
- 98-00 GS400 Compressed Air Coolant Flush/Fill Process
- Need some part #s
- oil filter
- denso oil filters
- Help removing front door panel LX470
- Air Wrench
- flashing AC light
- Get The Sc Buffed
- AC Compressor
- Tire Rotation
- Serpintine Belt
- Changing Tranny Oil
- Fuel filter changes
- T-IV synthetic now available!
- Palm Beach Lexus damaged my IS!!!!!
- 10K service
- Remote entry on 2001 IS300
- Maintenance Service Pricing - Lexus VS. Mercedes
- Questions about Repairing Power Steering Leaks
- transmission flush
- Bay Ridge Lexus / Parts Dept
- weird window problem
- Dim display--A/C fan Ventilation panel 95 Sc400
- front seats
- Who has changed out the brake calipers and/or ss lines themselves?
- Cleaning Air filter on Intake
- check engine light
- Replacing my fuel filter
- oil filter
- oem oil filter
- 45K Mile Maintenance Questions
- Power Steering Pressure Hose Install?
- headlights
- new window regulator broke
- UNREASONABLE Cost for 30k service
- $55 for oil change?
- raspy - scraping noise from undercarriage 2002 GS 300
- Toyota/Lexus part substitute
- Maintnance near Ocala FL??
- At a stop, steering is super stiff
- Bypass Pressure of 90915-20004?
- Some ? about stock SC filter
- A/C leak... anyone use those leak-enders in a can??
- TRAC light on after a cold start
- mighty a/c filter
- Very loud noise after replacing PS pump
- Sweaky Doors
- Flushing Radiator w/ Distilled or water from hose?
- Any reliable, independent mechanic in the Sacramento area?
- Power steering filters
- Cabin Filter
- Power steering fluid change
- Stock Brake Rotors
- Radiator Capacity
- Plug Change Rx 300
- A/C Question
- Changing Plugs And Wires
- Well how do you like that lexus Service!
- Help: Automatic Shifter locked
- Lexus maint. records
- How often do you change the OIL on your ES?
- 60,000 mile service....what's done?
- 60K mile service
- Where can i buy redline mt90 for cheap?
- Oil Light warning QUESTION?
- Help::A/C Problems
- Antenna removal
- a/c compressor oil?
- 94 SC 300 Instrument Panel Light Bulbs
- Oil Change and air filter...
- Cooling system questions
- ATF capacity of '98 LS400
- 100,000 Mile Spark Plugs?
- ES - fan switch problems
- Rx 300 Maint
- Am i Screwed?
- Transmission Fluid Issues--Help
- Best air filter for reliability/quality?
- Fluid level
- dealer satisfaction
- Brake dust
- LS - Adding Freon
- Oil for the LS 400
- Help with replacing my A/C Compressor on a 92 SC300
- what oil to use
- Please help a car dummy!!
- LS - Headlight Washer work intermittent
- antifreeze
- Antenna Mast replacement IS covered under CPO
- THIS is the German SYN OIL, I use.
- Tint Removal
- torque master plugs
- Fram xtraguard oil filter
- Steering wheel shakes!
- non-Lexus cars in Lexus service?
- WIndow problems ES 300
- Is $90 for oil/filter change right??!
- Where do you go for servicing your Lexus/Toyota? (SF Bay Area)
- 92 sc300 front and rear rotor removal?
- How Hard To Flush Rx Trans Dyi ?
- Air Struts to Coil Springs Conversion?
- My Ac is Charged but...... No cold air
- Synthetic oil question...
- what kind of oil do you use on your LS?
- Valve Adjustment?
- Need Advice on Strut Replacement for a ES300
- Grease Fittings
- What brand fluids should I use?
- LX470 Brakes
- instructions for replacing window regulator??
- LS - how to change spark plug wires
- Resetting the 'Check Engine" indicator on a GS400
- GS - Cost to service AC???? Does not sound right to me
- Antenna Replacement NOT Certified
- LS - A/C Finally Repaired
- LS - Popping sound from front end
- Transmission flush
- LS - Idle Up Valve
- feel downshifts
- help! I can't find my Lexus coupons
- Busted Dome (light)
- bouncing tach at idle after freeway speeds
- replacing the stater on GS400
- is this a good price for 60k service?
- A/C Heater don't workH
- Courtesy Light
- 120K service
- es300 PS belt removal....need some fast help
- Performance question for SC300
- gas pedal problem
- Check engine codes
- Automatic Trans Fluid $10.29 per Quart???
- Timing belt change!
- Is $250 a good price to convert AC from R12 to R134?
- Dealer overfilled my trans.. What to do?
- Transmission Fluid Change Interval
- Grinding pulse when stopping - bearings? (I've been told...) HELP
- 96 sc400 stainless exhaust tip question
- Need Brake Fluid Flushed - Lexus of Chantilly?
- MAF question
- 1991 ES250 Rear Wheel Bearing
- Curious about Dealer "List Prices" for Parts & Services
- 1991 ES 250 oil pan
- Dynomax length & performance
- Seat recline switch
- What should a 30K cost.
- A/C Evaporater
- front disc brakes - general question
- air conditioning on es300
- IS300 Maintenace
- Hood Wire
