Toyota/Lexus part substitute
Old Jul 27, 2003 | 03:39 PM
amoryb's Avatar
amoryb
Default Toyota/Lexus part substitute
I was having some window troubles in my '91 LS, so I pulled out the window motor and the actuator. I then pulled off the motor and pulled apart the gearbox. Therein was the problem, the rubber hub had ripped in two. This hub helps to smooth the transition between the motor and the cog for the window mechanism. It was late and I live aways from a dealer so $.74 of superglue did the trick for the moment. I haven't checked with the dealer on that part, but they probably don't just sell the hub I need. Does anyone happen to know if that part is the same on a Camry? I know there are several things that are different on the Lexus, but they didn't reinvent the wheel or anything, so there are some substitutes out there. If no one happens to know, I'll make a visit to a junkyard soon and pull one apart on a Camry and see if it is the same.
Amory
ilexusnow
Oct 5, 2017 09:06 AM
dinkel41
Aug 28, 2012 10:28 AM
option0002
Jun 21, 2008 01:56 PM
turbosix
Nov 2, 2007 05:47 PM
MFA
Jul 11, 2004 06:33 PM
