EBC Pads: Brake Dust!
Old Sep 8, 2003 | 10:58 AM
CoreY2K1's Avatar
CoreY2K1
Default EBC Pads: Brake Dust!
I installed the EBC brake pads on my 00 GS4 about 2 months ago, and they have produced so much MORE brake dust than the stock pads, it's unbelievable... Is this normal?
I went with the EBC pads based on recommendations from this forum. But I can't even go a week without getting a ton of dust buildup on my 19s. What's the deal with these?
-Corey
Old Sep 8, 2003 | 11:06 AM
redgs4's Avatar
redgs4
Which EBC pads? Only the greenstuff are low dust.
Old Sep 12, 2003 | 07:51 AM
Lexmexico's Avatar
Lexmexico
I use Greenstuffs on my front brakes for my 99 RX. I had a lot of dust for about the first month, but since then no problem. I seriously wonder which type of EBCs you are using or how you are braking.
Old Sep 12, 2003 | 08:19 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Sane with my EBC Greenstuff. More dust at first (you get that with any pad as it conforms to the rotor), then I see about the same dust as stock.
Old Sep 19, 2003 | 09:26 AM
link13's Avatar
link13
Default brake pads
I tried some Axxis pads on my GS3 and then ended up going back to the factory Toyota pads. I have honestly never seen so little brake dust as what I get with the factory pads. After a week, there's hardly any dust on the 19s. I have found that it's hard to go wrong with the Toyota stuff if you are not doing big brakes, etc.
Old Sep 20, 2003 | 06:50 AM
Lexmexico's Avatar
Lexmexico
I also like Toyota OEMs, but switched to EBCs on my front pads due to the fact that Toyota pads were not getting the job done in the bad traffic and steep hills here. Brake dust is the last thing on your mind in rough conditions. I have also tried Hawk brake pads and they did an excellent job with no brake dust, but not as much stopping power. EBCs, from my experience, seem to perform better in wet weather than Toyotas or Hawks.
addzlex
Suspension and Brakes
Sep 1, 2014 12:19 AM
heyitzalex
May 3, 2010 07:50 PM
JBasco20
Feb 26, 2010 07:28 AM
kilo6_one
12
Aug 4, 2006 01:05 PM
